Gear Drive on L98?
Gear Drive on L98?
True you can't run a gear drive on the L98 engine? Knock sensor problems? Timing cover issues with short water pump? Easy obstacles to overcome?
I was referring to the timing set.. Like a pete jackson or edelbrock or other brand timing gear drive. Sorry, guess I should have been a little more specific.
I am curious about this as well. I am ready to do new heads and cam. I would love to here the whine of a gear drive system. I know the nock sensor will give you problems. There has gotta be some way to get around it.
Received 3,043 Likes
St. Jude Donor '05
Some claim you dont get knock counts with it I might be inclined to disagree. Is it worth all the work to find out?
IMO do yourself a favor and stick with a chain unless youre building some carbureted street rod you only have out a few times a month on cruise night.
Besides a gear drive is not a good idea in most cases, no matter how quiet (or noisy if you prefer). The gears transmit much more of the crankshaft harmonics to the camshaft and valve train, than a chain. A belt drive transmits even less.
RACE ON!!!
RACE ON!!!
I agree! I kinda like the 'gear-whine' sounds of the gear drives too, but having seen/listened to dozens of small block Chevs/Vettes with these things, over the years - I would say don't do it. I know, some outfits make 'low-noise' versions of these drives, but the ones I've heard are still not that quiet that I would want it in a daily driver! Just my 2 cents. Cheers!
