anyone know how to fix this?
Originally Posted by rolando4812
using a fused jumper wire". how do i do this and can i get a jumper wire at auto zone or pep boys? thanks guys
"how do i do this" Hold one end of your "jumper wire" to one terminal while you touch the other end to the other terminal.
RACE ON!!!
Just use a paper clip. I have only ever used a paper clip, and don't know why you would need anything else unless you need a test light (i.e.converter lock up).
My '85 is always faster when cold too. I think it is because it is running so rich. My theory-- These cars love that. When the computer goes into closed loop, it leans out the mix to stoich. It does it for emissions.
I don't have any codes either.
Misread the post. Just use a long peice of wire from the battery positive lead to terminal G. You can run it through the window. That's what I do.
thanks cfi. how do i know when its 12 volts?
Put one end of your "fused jumper wire" to a known 12 volt source. The battery is often used. If you have any doubt as to whether a source is 12 volts, check it with your DVOM.
RACE ON!!!
