Brake conversion C4->C5->C6 Z06?
#41
I agree with Mojave. Everyone puts bigger wheels and tires on, but you don't hear anybody too concerned about unsprung weight with those.
Since there are no real differences between the C-5 and C-6 set-ups, stay with the C-5 upgrade since all the parts are proven to work on the C-4.
#42
Tom and I hi-jacked for a more detailed discussion about brakes because the topic of weight came up. We can take it offline if the OP would prefer.
#43
One of the most overlooked parts of a brake package is the caliper quality. The hi-volume Brembo brakes used on many street cars (EVO's, Mustangs, etc) are huge in size, but the caliper body is cast and not machined. It can flex more and therefore trasnmit less of its energy into stopping than an expensive aftermarket Brembo caliper.
But we're only talking street cars here so it doesn't matter, and knowing the full story and deciding whether it's relevant to those asking the question is not important, apparently...
#44
Hey guys, I need to shave a few ounces off of my brake and wheel setup. I lost an auto-x on Sunday because my brakes weighed 6 oz too much.
95% of the people in this thread won't ever exceed the braking capacity of their stock C4 brakes with craptastic parts store pads.
#45
The C6 Z06 brakes will not come close to fitting with the typical c5 brake adapters, even though you can directly bolt on the brakes to the C5. It all comes down to making sure the caliper and lines fit around the existing C4 spindle hub. I have gone through and made a bracket to work, but after talking to a couple of Corvette engineers regarding the Blue Devil/SS/ZR-1 car, I am not going to release the C6 Z06 kit. I do have a rear kit available, but it will also be mounted to one car and then never thought of again.
The Z51 front rotor is 13.4" The C6 Z06 is 14"
Thanks in advance
#46
I have seen them in person in GM's test lab. They are freaking ginormous. I suspect that they are made by Brembo or they are a 6 piston copy made by someone else. They use the biggest single brake pad I think I've ever seen -- the pad area is about a foot long by 3-4 inches high -- no padlets here. I didn't have a tape measure handy to measure the rotor so I laid a notepad across it and it is at least 14 inches.
#47
Brembo, AP Racing, Alcon, and Performance Friction all make brakes that large. When I worked on Daytona Prototypes last year, the caliper/pad/rotor combo was tailored to the track and race duration. We used to have some 12-piston Brembos laying around that carried a single pad approx 12" tall on a 15" carbon rotor. The problem with these things is cubic dollars. A "basic" 6 piston monobloc AP Racing caliper runs ~$6000 ea.
#48
#49
#52
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Make sure that C5 caliper (from the 12.9" rotor) will fit over the 14" rotor enough such that the pad doesn't hang past the edge of the rotor.
#54
After seeing more posts this week on the C4 to C5 brake upgrade I had to come back and read through this one again. Does anyone actually have any data that would suggest the C5 brakes are better than the C4 J55's? Stopping distance, track evidence, etc.. Who has experience with both and which are better? When my pads wear down I was thinking of switching to C6 calipers and rotors. Other than the looks is this a waste of money?
#55
Some people have had problems with the base J55 calipers flexing under hard load. The C5 calipers (and especially the C6 stuff) are forged and stronger than the earlier stuff.
#56
St. Jude Donor '03 & '05
But I asked if they could basically, with the same car, same tires, same track etc etc, try new 12 inch brakes OEM (same pad compunds), then upgrade to the 13 inch C4 brakes, and finally the C5 brakes systems.
So, same car, same pad compund, same tires track etc etc.
I got no response. But it brings up the point that to truly test wether there is an upgrade worthy here, you need to test all three sets, or more if you want to get into Brembos etc, on the same day same BAT CHANNEL!
