single plane
Old Nov 1, 2007 | 10:26 PM
crossfire7's Avatar
crossfire7
If it had another air filter lid, it would be "two turn tables and a microphone"
Old Nov 1, 2007 | 10:30 PM
anesthes's Avatar
anesthes
Originally Posted by AKS Racing
But something very similar does.
It all fits under the stock hood in an '87.
Aaron
Nice job!
I really really wish the air cleaner wasn't soo close to the headers..
Thats pretty much the only thing keeping me away from another blower.
I could get a head unit for cheap money, and make brackets but I don't want the inlet temps 200+ degrees. At least on the fbody, you could do 180 turn and stick the air cleaner in the fender.
The intercooler setups are nice, and I ran one for a short while, but after 20 feet of plumbing and a big IC (24") you lose 3-4psi right off the top. Almost not worth it. Alky injection however, that did the trick!
-- Joe
Old Nov 2, 2007 | 01:52 AM
Curveit's Avatar
Curveit
Originally Posted by cruiserto
Looks like a good idea to me. Maybe a bigger diameter housing; if possible, would be even better. It's probably a 4-BBL Throttle Body, for those who don't know. As with a Carb, heigth under the hood is limited for Air Filters.
thanks! your right it is a 1000 cfm 4 barrel throddle body "bigger diameter housing"? if you mean the the thing that looks like an air cleaner its just a houseing the pipe in front of it attaches to a c5 inlet hose and to get more cold air in note the fabricated piece to get more air from the modified c4 filter housing
I realized what it was right away, and like I said ...a good idea. While I don't know for sure about this type of TB, carbs like space around and above to breathe. I think it's 3 1/2" above a Holly, minimum, for good performance. That looks like a 10" houseing; a 14" might work better; more "area". Might not make any difference.
AKS Racing...I've always liked the looks of that plenum you made. I wonder how well it would work NA ?
Old Nov 2, 2007 | 07:54 AM
Blown Vette's Avatar
Blown Vette
I made that plenum back in 1990 and sold it along with the whole setup(manifold) here about two years ago. You may want to consider a 4bbl t-body if NA. It will respond much better. That is what I am going to use on my aluminum 427 pump gas motor.
Old Nov 2, 2007 | 10:10 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
The idea to use a single plane intake for EFI has been around for quite some time. Jeb and I put together one that many forum members have been using on their 383+ motors.
Our setup fits under the stock hood and works as good as anything out there. I tested is A-B-A back when I was running a 406 SR motor and the car gained in every interval of the track - check the archives for details/specifics.
Here is a shot of mine:
The car doesn't seem to have lost any bottom end with the shorter runners
Old Nov 2, 2007 | 06:54 PM
cruiserto's Avatar
cruiserto
Default very nice
your air to fuel ratio caught my eye for max h.p I will keep that in mind. I cant help but wonder what it would do with say my set up, But I have to say that yours is quite impressive
G
Old Nov 2, 2007 | 06:59 PM
cruiserto's Avatar
cruiserto
Interesting nice work
G
Old Nov 2, 2007 | 07:02 PM
cruiserto's Avatar
cruiserto
naw I would use cd's
Old Nov 2, 2007 | 10:26 PM
pr0zac's Avatar
pr0zac
you sell those? if so how much? pm me please
Old Nov 3, 2007 | 09:09 PM
Cutter1's Avatar
Cutter1
Originally Posted by chriswtx
How about something like this...
Check out the flat torque curve on this tunnel ram..
What did this intake start out from?
Old Nov 3, 2007 | 09:23 PM
chriswtx's Avatar
chriswtx
Holley pro dominator tunnel ram...
Old Nov 3, 2007 | 11:37 PM
Random84's Avatar
Random84
Well ok it doesent look like a conventional corvette set up, but if you
are into preformance you would understand
I have never seen a carb do anything EFI can't do - and EFI can likely do it better (equal or greater HP, with increased efficiency).
The limiting factors are typically the use of an OEM manifold (and more typically: the tuning capabilities of the installer).
Carbs are a more simple beast and are easier for the home mechanic to dial in (but not necessarily the be all, end all for "performance").
Cool setup.
Old Nov 7, 2007 | 10:08 PM
  #33
cruiserto's Avatar
cruiserto
Default Injectors
I would like to ask, what size fuel injectors did you run?
"G"
Old Nov 7, 2007 | 10:10 PM
  #34
cruiserto's Avatar
cruiserto
Default efi
It's not a carb IT is EFI that's what I am talking about
