1986 iron head motor pistons ???
What type of pistons does an iron head 86 motor have ?
What compression would a 64cc chamber make on one of these motors ?
According to Mike Antonick's "Cor-Vette Specs," the 86 has "impacted cast aluminum" pistons weighing 21.1 oz each. And I thought the heads iron heads were 64cc stock. Could be wrong though.
[RICHR]
[RICHR]
76cc ??
for some reason i was thinking they where 76cc 624 casting heads.
I think I had read that somewhere. I could very well be wrong though.
The 1984 - 1986E, 624 heads ARE 76 cc. You can figure your stock clearance volume from the CR. Then subtract the the difference in head volume (76 - 64 =) 12 cc and re figure the CR with the new, smaller, clearance volume.
The 1986E pistons carry a different part number than the 1984 - '85 forged pistons. Because of the different part number, I had always guessed that they were cast.
RACE ON!!!
RACE ON!!!
Cor-vette specs also states:
Your stock compression ratio is 9.5/1
Your head gasket thickness is .021 (which you could increase in size to slightly decrease your c/r)
I just built a vortec engine with 64cc heads. I used flattop pistons and, I believe, a .045" thick head gasket. That combo yielded a 10/1 or maybe 10.1/1 ratio which is a bit high, but with the right distributor you can control your advance curve to keep from having detonation problems.
If you do have a slight dish piston, you will likely have a ratio in the high nines.
BTW, with a comp 262H cam with .469 lift, my dyno sheet shows 372hp @5100 and 422# tq @4200 with a poorly jetted 725 holley (just for the dyno, plan on L98 intake). With the L98 intake and a good tune you should be able to surpass these #s.
I honestly had no idea that the 86 had such large chamber heads.
Received 1,400 Likes
They are cast pistons.
RACE ON!!!
flat tops...
9.5/1 with 76cc chamber would almost have to be flat top.
Seems like it would even be less than 9.5/1. More like 9/1.
Chevrolet must have been a little optimistic on this one.
pinging
I have an 86, and even with the stock heads, it always pinged.
I got 88 aluminum heads, cleaned up the chambers a little, and put a thicker head gasket(.040 squished), with multec injectors, and it pings slightly. mods include throttle body bypass, and mat relocation.
I did a rebuild on my 350 in my 57 Chevy truck, and it's a 4 bolt 2 piece seal 350, hypereutectic pistons, '88 corvette 128 heads, and with the 1.5 roller rockers, no pinging. With the1.6 roller rockers, it pings all the time. I went back to the 1.5's.
The cam is a crane cam with 266 duration, .487 intake,.492 exhaust, and timing is initial at 8 degrees, with a total of 34 degrees at 2900 RPM with a msd billet distributor run off an MSD-6-al box, adjustable vacuum advance, and a light spring with a medium spring, and modified advance weights.
With a 160 thermostat, aluminum radiator, oil cooler, edelbrock alum. water pump, it runs at about 170 all the time, sooooo
with a 3:38 rear, traction bars, sway bars, 4 speed, it is pretty quick for a 50 year old............now if I could only stop and turn fast.....
anyway
The rockers make a big difference in the SOP dyno. I seem to feel the acceleration difference and at the same time, hear the ping, especially like in an alley with block walls on either side. Or in traffic with a semi on each side. So watch the cam plus rocker equation when you decide to upgrade.
anyway
Ooops
I forgot to mention that my block is .010 decked and .030 bored, which gives me a little higher compression than a stock block.
Is it vortec heads you're looking at? I think it's a great choice for buget performance. Especially since you can get RHS vortecs (assembled) with .500 springs for under $650! And the flow numbers are huge and the design should really complement the high-torque L98 intake.
I have a SBC chart on my desktop that shows flow #s for many stock and aftermarket heads. You'd be suprised how well they measure up. They blow the doors off of World SR Torquers, for example.
