Where is the C-100 connector to the left of the clutch pedal?
I'm going to be installing my shift light soon and after reading the write up on hashmarks.com http://www.hashmarks.com/ShiftLight/page5.html
I decided that's the best route to follow. I'm kinda stuck though, I've looked all over for this mass of wires and I can't seem to locate it. There is the indentation in the carpet by my left foot, but I can't seem to pry that off either. Hints?
Thanks,
Sam
Thanks,
Sam
Re: Where is the C-100 connector to the left of the clutch pedal? (vetsvette)
I think the C-100 is part of the pass-thru connector on the firewall, may be wrong, but I think that is it.
Tom Melton
82 CE
86 Z51 Coupe
Tom Melton
82 CE
86 Z51 Coupe
Re: Where is the C-100 connector to the left of the clutch pedal? (tommelton)
Tom Melton
82 CE
86 Z51 Coupe
Tom Melton
82 CE
86 Z51 Coupe
Cruise-In II Veteran
Tom Melton
82 CE
86 Z51 Coupe
Tom Melton
82 CE
86 Z51 Coupe
Re: Where is the C-100 connector to the left of the clutch pedal? (Thumper)
Hmm, I'm 6'4" and over 200lbs, I have crawling under the dash! Thanks all for clarifying that it's not beneath the carpet, I'll keep looking.
Sam
Sam
Re: Where is the C-100 connector to the left of the clutch pedal? (LT4Sam)
I hooked up a tach some time back on the 95 and the connector was on the left of the clutch pedal where the bunch of wires come thru the firewall. You have to remove the lower dash cover to see the connector. It's not too bad, just not much room. Move the seat all the way back. Good luck. Sid.
