DFI OR FAST
Re: DFI OR FAST (miker61588)
No comparison - the SpeedPro/F.A.S.T. It's worth the money, but it depends in what you're building. The DFI system, especially the new DFi 7.0/Calmap2000 is a nice system and works very well. For a street setup it's plenty adequate, and there are plenty of racers that use it as well. But when you want to get serious or if you are going to race competitively, the F.A.S.T. system is the way to go
I had the Accel DFI on my last motor, a SuperRam 383, and now have the SpeedPro/F.A.S.T. on my SBC427.
Re: DFI OR FAST (SloRvette)
Exactly. That's what I have SpeedPro Sequential, Wide Band O2, and Individual Cylinder Fuel and Timing Control. Nothing easier than typing in an A/F ratio, and the ECM adjusts the pulse width to achieve that A/F ratio. The you just adjust the applicable VE point by the appropriate O2 correction percentage for zero O2 sensor trim. WHen I had my motor on the dyno, and we were tuning for peak torque, we tried A/F's from 12.7 to 13.2. Ended up making maximum torque at peak with 13.1 A/F, gained almost 20 ft lbs compared to 13.0. Lost 8 ft lbs at 13.2. Not many systems allow that amount of granularity.
where can i buy the fast with wideband any good places that sell it cheaper then others? if i dont get the wide band option can i use the regular set up with a blower?
Felpro unit, called Speedpro now, is the way to go.
I have it on my car, wouldn't trade it for nothing.
It makes everything easy....
If you're serious, my friend is a dealer for them, maybe he can help u out on price. If interested, let me know.
Good luck.
[Modified by QUICK 35TH, 9:46 PM 11/21/2001]
Good luck.
