C-4 driveline Beam plates
Re: C-4 driveline Beam plates (silver & red CE)
The above object I detailed out does NOTHING to help the beam, flex of the car, traction, etc. They will however help you not to want to toss a wrench across the yard & they will hold the nuts in place while you tighten the bolts. If you can make a set then more power to ya.
I'll make this real simple, OK figure out what the front & rear nuts measure. Hint: The socket that fits them will tell you the size. Get some stiff material, Cut it in a shape of your choice with two slots that will fit said nuts. Figure out how far apart to make the slots by measuring the distance between the bolt holes in the beam under your car. Poof you have a set of nut holders. Happy ??!?!?!!!
I guess since I made my own shifter **** I should keep it quiet so I don't upset anyone. :crazy:
Neal
Neal
