gas smell from engine comp
Nov 27, 2007 | 05:12 PM
87 350 tpi getting gas smell can't find any leaks any suggestions
Nov 27, 2007 | 05:21 PM
one possability is your fuel pressure regulator
Nov 27, 2007 | 07:46 PM
i think your car has a cold start valve (csv) or a "9th injector". look (and feel) at/around the connection at the back of the fuel rail near the left valve cover.
Nov 28, 2007 | 09:04 AM
Also, sniff around your charcoal canister and it's hoses.
Nov 28, 2007 | 09:32 AM
Quote:
Originally Posted by
AGENT 86
What do you mean when you say "charcoal canister"? I have never heard that term before.
Nov 28, 2007 | 09:42 AM
Nov 28, 2007 | 09:45 AM
Nzzz
Mine was leaking too. I took all that out and rerouted the gas fumes into my wheel well
Nov 28, 2007 | 10:03 AM
O ring on an injector maybe leaking. Only had a gas smell when the engine was cold, opened the hood and saw a small puddle of gas on the intake by the leaking injector. Replaced all the o rings and problem solved.
