Still lookin for a coolant leak
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Ive been lookin but cant find anything. I get a slight smell of coolant outside and a small leak, about 1 gallon in the last 6 months and 8000 or so miles. I suspect the waterpump, guess Ill have to get a pressure test
Re: Still lookin for a coolant leak (lou sylvestri)
You might check to see if the heads are "weeping". I'm told that mine are. If I drive it hard, I can smell the antifreez, but there is no appreciable loss of fluid. Maybe this winter I will have the head gaskets replaced.
My $0.02 :seeya :flag
Re: Still lookin for a coolant leak (91 black convert)
Re: Still lookin for a coolant leak (My 95)
Visual inspection is what I had in mind.
If you can get it up on a lift, look for leakage that shows up below the heads, not from below the valve covers.
Jim S.
Jim S.
If it's an LT1/4 H2O pump, the most common first sign of it going is a small leak out of the weep hole. Weep hole is located on the bottom of the pump housing directly over the serpentine belt/harmonic damper. If it's leaking you'll feel a few drops after the motor heats up to operating temp. A leaking pump can take out the optispark, I'd be sure to check it soon.
Another sign of the H2O pump going on an LT1/4 motor is the power steering goes out intermittenly, the coolant leaks on the belt and the belt slips.
Hope this helps,
Eric
[Modified by silver & red CE, 9:54 AM 11/23/2001]
Hope this helps,
Eric
