The Battery voltage and coolant temp is very dim on my 85
The Battery voltage and coolant temp is very dim on my 85's Dash
well,I just bought this 85 and already I have some issues...Everything on the dash reads out fine and 90% of the
displays are very bright except for the little square box around the batt voltage and coolant temp. The batt voltage,
coolant and the average - instant numbers or segments are also dim to. Is one of the replacable bulbs blown out
#882 or do I have a bad display.
Thanks for any suggestions
[Modified by Daves85, 6:25 PM 11/23/2001]
Re: The Battery voltage and coolant temp is very dim on my 85 (65Z01)
I will take a look at the 4 bulbs ..1 may be located behind that part of the display.
