Aftermarket power steering Hose 1987
I know the Kragen power steering pump pressure hose will not thread into the steering rack. The steel end of the hose is not bent the same as the original hose.
Just purchased a NAPA aftermarket hose, hope it works.
Where is a good place to buy a new hose if my NAPA hose will not fit?
If you run out of alternatives, try going to a shop that specializes in hydraulic hoses. They might be able to bend new connectors and build a hose for you. PS pressure hose is different than typical hydraulic hoses so check first to see if they can supply the hose material.
Some shops that specialize in brake work and parts can build hoses too.
