Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Reload this Page >
question for guys running compcams pro-magnum roller rockers
Old 11-25-2001, 01:31 AM
89formula
CF Senior Member
89formula's Avatar
Liked 0 Times in 0 Posts
Default question for guys running compcams pro-magnum roller rockers
what kind of valve covers are you guys using? i have a hacked up set of stockers but they leak a little bit. is there an aftermarkey pair that will fit or do i need to grab a set of lt1 corvette covers and trim the insides out? what worked for you?
thanks,
89
89formula is offline
Old 11-25-2001, 01:56 AM
65Z01
CF Senior Member
65Z01's Avatar
Liked 94 Times in 88 Posts
Cruise-In II Veteran
Default Re: question for guys running compcams pro-magnum roller rockers (89formula)
I'm running modified Vette valve covers over my 1.6:1 ProMagnums. Cut the drip tabs down and trim the sides of the bolt bosses.
Assure that both surfaces are clean, install the FelPro PermaSeal dry gaskets and torque the boltsdown in successive stages.
65Z01 is offline
Old 11-25-2001, 01:02 PM
mackeyred96
CF Senior Member
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Liked 2 Times in 2 Posts
Cruise-In VI Veteran
Cruise-In VII Veteran
I'm running the 1.5s and had to do very little cutting.
mackeyred96 is offline
Old 11-25-2001, 06:23 PM
nickd
CF Senior Member
Default Re: question for guys running compcams pro-magnum roller rockers (mackeyred96)
I have heard the composite covers (LT1) are good if you are using non-self aligning rockers.
Keeps the rockers a little less noisy.
nickd is offline
Quick Reply: question for guys running compcams pro-magnum roller rockers
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
