HELP;Brains needed.
Few weeks ago at the strip experienced slight miss above 4000 at WOT.Then I fitted the superam in place of the old TPI system and boy did the RPM limit jump but still with the miss.Just put in the PCM chip hoping for a cure all.
First the car wouldn't idle so I reset it as per Gordons directions and now it's OK at around 700.Bit lumpy but that's the cam.
Gently on the gas and it pulls all the way up to about 6300-I chickened out
WOT and anything over 4000,bang pop boom.
Increased fuel pressure and it does seem to get better as far as the miss is concerned but at idle if you stand behind the car it will kill you.Called Lingenfelter and the really unhelpful guy reckoned my setup should run 58psi.I don't believe him for some reason.
One interesting fact was having tried time and time again to get the history on this car from Lingenfelter including talking to John before his untimely demise was when I pulled the chip stuck inside was a note that said Lingenfelter racing,87Y,180,700,and a signature.
Anyway I digress.Can this thing be plugged into something that will tell me if this is ignition or fuel related because I don't know which way to go next.Thanks in anticipation.Dave.
another option is put a scanner on it AZ should have one for use as a loan-a-tool, just not sure if they will have the adapter for the OBDI connector, but they might.
Anyway I'm in the process of changing the plugs and the module.Plugs are starting to be fun because when i rebuilt the thing I put in the plugs before attaching the headers and dropping it into the car.and two are impossible to change.Have to be constructive tomorrow and fabricate a wrench.Keep it coming guy's.Thanks.
Bob finally gave up and did a compression check, all was well, then used a dial indicator on all the rockers, and he got different readings depending on the wear. (i think)
Anyway, it would rev to the moon as long as he didn't mash the throttle. same M.O.
I don't know Rel3rd or bob but my comps are OK as are my rockers and my cam has been performing for over twenty years now.
How do you dial in a rocker???
(I think)
As for MO's-I hope you fly your avatar and not be one of the guys that fix it.That would be really scary.
If your fuel pressure is OK, check your MAF. Dirt build up on the heated wire will reduce the signal from the MAF to the ECM, and lean out your engine to the point of a misfire. If this is the case, it can be cleaned.
How about the distrubutor cap? If you haven't replaced it yet, it could be cracked. If it is an ignition misfire, the extra fuel at WOT would add extra resistance to the ignition system, and the spark could be jumping around inside a cracked cap. You will usually see evidence of carbon tracking inside the cap if this is the case. Worn distributor shaft bushings can cause random ignition misfires upstairs as well. Would you say it is an erratic misfire, or more of a steady one when it does it?
(I think)
Paul
Fuel filter or pump would be worth looking into. A few other places to look... 35 gap on the plugs, plug wires
