Help with 84
Old Dec 30, 2007 | 09:13 PM
red vet man's Avatar
red vet man
Default Help with 84
Car wont start has new fule pump and sending unit, new relay has spark at the plug turns over fine, wont start, cant here fule pump runing this car has run with all the new parts and the car has been stored and not started in 7or8 month's. also at times their seems to be a short in some of the wires located on the wheel well drivers side.
PLEAS HELP
Old Dec 30, 2007 | 09:29 PM
qws's Avatar
qws
Did you check your fuses? The fuel pump relay is located on the fire wall of the drivers side. Once in a while my connector will loosen up and keep the FP from turning on. Thats something easy to look at. If you don't have a FSM manual that would be a good thing to have. That will be your best friend.
If you know how to use a DVM then you may need to check and see where and where you don't have voltage when the key is on.
here a wiring diagram http://misterbill.homeip.net/vette/wiring/
Old Dec 30, 2007 | 09:37 PM
lil_Mike's Avatar
lil_Mike
if you remove the cover do you see any gas sprayin from the injectors
Old Dec 30, 2007 | 10:01 PM
red vet man
nO FULE AT THE INJECTORS
Old Dec 30, 2007 | 10:04 PM
red vet man
[QUOTE=red vet man;1563385336]Their is no fule at the injectors
Old Dec 30, 2007 | 10:15 PM
qws's Avatar
qws
If you don't hear the fuel pump turn on when you turn the key on I doubt you'll have gas at the injectors.
Check your fuses..do you have voltage at the pump when you turn the key on? Work backwards, it sounds like an electrical problem
Old Dec 30, 2007 | 10:34 PM
red vet man
What is the best tool to check for voltage its not my fuses unless their somewhere else other than on the passanger side
Old Apr 12, 2008 | 10:31 AM
FSmileys's Avatar
FSmileys
under the hood right hand side there is a relay for the fuel pump check it. there are 3 in a row its the middle one
Old Apr 12, 2008 | 09:34 PM
Brimis's Avatar
Brimis
I launched the link to take a look at your car and I'm bring greeted with a login script.
To Help with 84
