Forgot to use anti-seize on sparkplugs,will it be ok?
After putting the plugs in my 94 vette,what a job that was,i forgot to use anti-seize, i hope this will be ok, because i dont want to go through the plugs again,should it be ok? THANKS MIKE
Re: Forgot to use anti-seize on sparkplugs,will it be ok? (CORVETTE MIKE)
I don't know if I would chance it. Aluminum and steel do not mate well especially when heat and electrical current are introduced. A couple hours of back tracking may stop a lot of headaches(galled and stripped threads, broken plugs, helicoils :sad: ) down the road. just my $.02.
Bart
Bart
I've never used anti-seize and I've never had a problem. Just be sure that you remove and install the plugs when the head is at ambient temperature.
Received 1,400 Likes
Re: Forgot to use anti-seize on sparkplugs,will it be ok? (jfb)
if you get time to do it then go back and do it.
How much anti-seize do you put on?and do you put it on the sparkplugs threads only?
Why in the world would you use anti-seize!! Your aluminum heads are mounted to a steel block. You don't worry about them do you? I know plenty of people that race and they don't use anti-seize. Just seems like a lot of mess for no gain! :rolleyes: :p:
Re: Forgot to use anti-seize on sparkplugs,will it be ok? (Camvette)
I have used Anti-Seize (on a Jag XKE - Alum. head) and had a plug seize and take out the threads.
I have never used Anti-Seize on my 87 Vette heads, and never had a problem (just changed plugs last month, and they were in there for 3 years - 50K miles).
My car probably had the original plugs after 52000 miles, they came out just fine. When I did my cam and such I put new plugs in. I got anti-sieze but my friend put the plugs in when I wasn't there, so much for that. Anyway, several months later I pulled them out no problem. I put them back WITH anti-seize just to be safe. I don't figure it would hurt anything and could prevent problems in the future. I don't think it's required, but I would do it next time just in case.
Re: Forgot to use anti-seize on sparkplugs,will it be ok? (Nathan Plemons)
I have a 92 with 102K on the clock. I'm getting ready to pull the plugs. I have all the service records on the car and I see no mention of the plugs having ever been changed...so these are the originals I believe.
Did the factory use anti-sieze when they installed them? And...is there anything in particular I should do to avoid damaging the heads when pulling the old plugs?
Cruise-In II Veteran
CORVETTE MIKE, I put a little antisieze on my finger and wipe it around the threads. Then I smooth it around the plug and wipe it off my finger with a paper towel (don't get any on the insulator).
Let the motor cool down before removing bolts (or plugs) from Al to minimize the chance of gauling.
I was told by G.Killebrew to always use antisieze where steel bolts go into Al. If you ever have a bolt gaul and brake off you'll think the fuss is well worth it.
Re: Forgot to use anti-seize on sparkplugs,will it be ok? (emoshn)
Mine had 40,000 mi. on with the orig.plugs,and they were so tight i had to use a braker bar ,but they came out ok.
1 Post
Anti-seize application has nothing to do with aluminum on steel. Electrolysis needs two metals PLUS the presence of moisture. I doubt much moisture exists on spark plug threads! You should use anti-seize because its CHEAP insurance against stuck threads and the resultant galling.
I use it on ANYTHING that I assemble. Avoid using too much, because the anti-seize contains minute particles of aluminum, and, if it gets on the spark plug porcelain, it could short the spark. :chevy Oh yeah, one more thing: I've found that engines that are burning some oil can get away more from using anti-seize, because the oil creeps up on the threads. If your motor burns clean, you better use the stuff.
[Modified by GRX, 12:44 PM 12/7/2001]
Re: Forgot to use anti-seize on sparkplugs,will it be ok? (GRX)
Yes but my plugs are already in and i drove my vette twice since then but only on short trips,will it be ok to take them back out and add anti-seize,or should i let them go.the plugs been in for about two weeks.Is that to long or will i be allright? THANKS MIKE
What Grx Said. The electrolyte doesn't have to be moisture though I don't think, but I don't know what it would be, since gasoline is not a conductor. Contaminated oil with water would be though I would think. Just my guess.
If you ever had a boat in salt water with steel washers on an aluminum engine, you know first hand what happends when dissimilar metals are put together in an electrolytic solution (ie salt water). It's ugly and costly.
[Modified by torchred96, 9:23 PM 12/7/2001]
It's your vette, treat it right.
It takes less than 30 min to remove and install my spark plugs. Pull 'em and sparingly apply anti-seize. A copper based anti-seize is also available. You need to use anti-seize to:
1) Allow easy installation and removal of plugs (no breaker bar needed even after 60K miles). :smash:
2) Provide proper lubrication to obtain correct torque.
Attention to detail and good engineering practice, such as applying anti-seize, are what separate a professional from a hack.
Re: It's your vette, treat it right. (Turismo)
One doesnt really have to worry too much if forgetting to use anti seize.BUT,if you plan to drive the car for years and do the job again,Id use it.Ive changed plugs many times on different motors with aluminum heads and they had no anti seize to begin with.
On high mileage cars with stock plugs,I would spray around the spark plugs some brake cleaner and use an air hose to clean any dirt away then spray WD-40 around the plugs,so when taking them off, the lube kinda works its way down on the threads easing it to come off then bone dry and possibly galling the heads.Ive never stripped a bolt this way.I hate taking them off when theyre bone dry from the factory.
And I always used anti seize after that on new plugs and parts that need it..On some jobs,like exhaust manifold bolts and etc,4 years later they came off easy because I had used anti seize there.Without it,they would have snapped off or stripped out.
Dont panic that you dont have any on there now, but as I said,it will pay off down the road if,on a free day you take some time to remove the plugs again and apply a little bit around the threads.Dont need to cake it on,just a little dab will do ya.Just dont wait a few years before doing so.
