Crank underdrive pully on L98, thoughts? Guesses?
I picked up a single crank underdrive pully last night for $25. :) Hey why not, ya know?
I already removed my AIR pump, and I'm not going to buy/install an alternator pully just to stress it out more (I say that now).
What are we talking here at best to the wheels? I'm not expecting much at all (if anything), the price was right, so I took it.
Re: Crank underdrive pully on L98, thoughts? Guesses? (scorp508)
The only question I have about it is how will it affect cooling? The water pump will turn slower, thus slower circulation?
I know when it get 100º+ down here..I need all the circulation I can get..:)
Re: Crank underdrive pully on L98, thoughts? Guesses? (BADMUDE)
Cruise-In II Veteran
Based on an earlier thread on differences between Net & Gross HP ratings I'd guess about 5-10hp gain from an underdrive crank pulley.
BTW, I have the March underdrive crank pulley only installed:
1) while sitting in line at the strip I have to run my engine at about 1,000rpm or so to maintain 155deg F coolant temp.
2) with accessories on the voltage drops to about 12Vdc.
3) I didn't measure any trap speed increase but was having ESC problems at the time.
Scorp, go ahead and swap it. (You may need a smaller belt.) As long as you don't run the alternator underdrive pulley with it, you won't have any issues. I've run both before, and if you don't do a lot of highway driving, you would have a battery charging problem. I have never encountered any issues running just the crank pulley.
Re: Crank underdrive pully on L98, thoughts? Guesses? (h rocks)
65mph = 1850 RPM
80 mph = ~2300 RPM
I have one. I currently use just the Crank pulley. When I use my stock chip and small alternator pulley, I have problem with the low voltage light comeing on, if idle a lot. With my aftermarket chip (and it 100rpm higher idle) I don't have a problem. I can't remember if I have tried using the stock chip with stock alternator pulley. I personally don't think there is much of a gain with a L98 underdrive pulley, I sure didn't feel it.
1 Post
Re: Crank underdrive pully on L98, thoughts? Guesses? (dgoodhue)
March Performance makes a Power & Amp series set. It's a crank, water pump & alt pulley set but the alt pulley is smaller than stock to keep charging where it should be. Works great, I have never had cooling problems even with a modified motor, YET. As for the one crank pulley I'd say go ahead a swap it. Hey, for the money it's worth a try.
Cruise-In V Veteran
Re: Crank underdrive pully on L98, thoughts? Guesses? (john25)
Scorp,
Just remember, Do not believe everything you read.
I have the underdrive pulleys on and my alternator.Volts is fine. My cooling at idle is fine too.
For a 20 min job even if it is only 1 hp it is definately worth it when you put it all together.
