What would cause the rear end to "dance" when upshifting gears. Now I'm talking about the 4+3 tranny, so pretend I mean the A4. When auto-shifting from 4-4/OD (like an automatic) the rear end sorta feels like the back left dips, comes back up, and torque steers ever so slightly.
I'm thinking the torque beam bolts came loose? Maybe? I leave in about 45 minutes for a 4 or 5 hour drive down to NJ. :D
Re: [WOBBLE]: Rear "dances" on upshift. (scorp508)
considering I am coming from the south... I won't be passing anyone here!!!
ok... a long time ago, someone mentioned the rear end has some kinda thingy that aligns the rear end... and they wear out... I think it is effecting mine. I am planning, upon the start of a new job, rebuilding the rear suspension...
No leftovers thankfully. :) Perhaps I did not torque down one of the camber bolts enough?
It is now noticeable when I just let off and get on the gas at all. The fast I am going, the more pronounced it is. The sensation it makes is like the right tire gets the power first, kind of leaving the left end behind, then it catches up. So she sorta "squirms" momentarily.
After ujoints? No. The reason for scribing the camber bolts before loosening them is so that you don't have to get it aligned after.
theoretically... except the half shafts are the 5th link, and can effect camber if worn!! you may be running slightly positive camber... which would cause this problem.
My 92 LT1 Coupe displayed the same symptoms. The best way to check and determine the cause is listed in the procedure I have written below. Good Luck Scorp. I would bet money that this is your problem.
Checking the Rear-Toe Link on the C4 Corvette
1. Jack up the rear of the car.
2. Leave the wheel bolted in place
3. Position your hands at the 3 o’clock and 9 o’clock position
4. Throw your body weight into the wheel, alternating weight from one side to the other.
5. Observe the tire & wheel to see if it indicates the slightest movement.
6. If it does, the rear toe-link is bad.
NOTE:
If possible, try to have a friend shift the tire while you observe the rear toe-link at the point where it is attached to the rear wheel assembly. Most likely, you will see the adjustable ends on the toe-link flex while observing movement in the rear wheel assembly.
The toe-link is relatively inexpensive and easy to replace. A rear wheel alignment will be necessary once the repairs have been performed.
Purp
