1.5 vs 1.6 Rocker arm ratio
Old 04-30-2008, 02:18 PM
flatbush862
flatbush862's Avatar
Default 1.5 vs 1.6 Rocker arm ratio
If the Stock L 98 cam -1990 corvette lift is
.413 Intake
.428 Exhaust
with a 1.5 rocker arm ration what would it be with a 1.6 rocker arm ratio?
I am trying to see what the #113 head flow difference would be based on the lift.
Old 04-30-2008, 02:22 PM
96GS#007
96GS#007's Avatar
Received 1,662 Likes on 1,023 Posts
.413 Intake
.428 Exhaust
If the numbers you quote above are at the valve, divide by 1.5 and then multiply by 1.6. If the numbers above are the camshaft lift numbers, just multiply.
Old 04-30-2008, 03:32 PM
KoBrah1
KoBrah1's Avatar
Also, remember that the stock rockers arms, even though they are rated at 1.5, are probably less than that. So going with after-market 1.6 rockers will actually give more of an effective valve lift.
From what I've read, stock rockers are more likely in the area of 1.45
Jake
Old 04-30-2008, 03:45 PM
vader86
vader86's Avatar
Received 1,398 Likes on 1,015 Posts
Most specs are quoted with 1.5s, divide by 1.5 to get the lift of the cam. The specs you have there are with 1.5s.
Then multiply by whatever rocker ratio you want to run.
Old 04-30-2008, 04:55 PM
Kool88vette
Kool88vette's Avatar
I believe you add .030. I did this mod. I read that you get an additional 15 chp.
Old 04-30-2008, 05:55 PM
87L98Z52
87L98Z52's Avatar
It would give you
.440 int
.456 exh
Old 04-30-2008, 06:12 PM
BILLY D
BILLY D's Avatar
A 1.6 rocker roughly adds 30 thousands lift. .413 + .030 = .443 and .428 + .030 = .458.
Billy
Old 04-30-2008, 06:37 PM
87L98Z52
87L98Z52's Avatar
You cant just add .030.It doesnt work like that.
If you have .500 lift with a 1.5,a 1.6 would add .33 and give you .533
A .600 lift with 1.5,a 1.6 would add .40 giving you .640 lift.
.413 lift with a 1.5,a 1.6 would give you .440,adding .27 of lift.
You have to take the lift number with 1.5 and divide it by 1.5,then multiply by 1.6.
.413 divide by 1.5=.275,now multiply by 1.6=.440
You just cant add .030 to any lift if your going to 1.6.
Old 04-30-2008, 07:16 PM
BAM92
BAM92's Avatar
Just take the lift, divide by 1.5, then multiply that amount by 1.6 to get the new lift number. And of course it doesn't effect the duration.
Old 04-30-2008, 07:54 PM
CFI-EFI
CFI-EFI's Avatar
.413 Intake
.428 Exhaust
Wasn't this one of the questions on "Are You Smarter Than a Fifth Grader?" last week? Basic, simple, arithmetic.
RACE ON!!!
Old 04-30-2008, 07:57 PM
flatbush862
Got it .440 Int., .456 Exh.
87L98Z52 calculated correctly above.
So from your website (below) :
Here are some intake flow numbers for #113 heads from TPIS "Insider Hints":
Lift......Stock......Ported
.100"......62...........68
.200".....116.........149
.300".....161.........193
.400".....185.........211
.500".....195.........211
.600".....198.........211
Note that the "Ported" numbers were with 1.940" intake valves.
That would put the intake flow @ 189cfm - correct??
To 1.5 vs 1.6 Rocker arm ratio
Quick Reply: 1.5 vs 1.6 Rocker arm ratio
