Help car won't start!
Old May 2, 2008 | 11:26 PM
jfb's Avatar
jfb
If you follow the recommendations in my post you will find your problem. I have one more recommendation. It is possible that the start enable relay contacts are dirty/pitted and will not pass enough current to pull the starter solenoid in fully. If you measure the voltage on your clutch safety switch when you hit crank position on the ign sw, you should see 12v. Also, if the battery or its connections won't hold up above 9.0 volts during cranking attempts, jumping the battery may not allow cranking either because the resistance of the jumper cables and the connection resistance is too high to provide the 100+ amps the starter requires.
If you want to truly find your problem, you MUST make some measurements while someone holds the ign sw in the crank position. Read my post and stop doing things that don't show where the problem is.
Old May 2, 2008 | 11:44 PM
jimmers's Avatar
jimmers
Originally Posted by DBall
Jimmers,
Based on the above, I would say you have a bad ground connection or positive connection at the terminals on the battery. My guess is corrosion on the ring connectors. Either, that or at the frame. Take them apart and check for any corrsion and clean them. You said another battery did not work, did you actually jump from the spare battery directly to the starter ? You could determine if it is a starter , battery or cabling problem. DB
I sanded down the battery cable connections but it didn't work. I also sanded all the grounds I could find. I tried to jump the starter directly from another battery but it didn't work. Nothing happened so I'm assuming I did it wrong.
Old May 2, 2008 | 11:46 PM
jimmers's Avatar
jimmers
I will give that a try tomorrow when somone is available to help me. I didn't have anyone around tonight to help. Thanks for your reply, I'll report back tomorrow with my findings.
Old May 2, 2008 | 11:49 PM
jfb's Avatar
jfb
No information indicates you did anything wrong, HOWEVER, you haven't measured even ONE voltage in your electrical system. You can buy a digital VOM (voltmeter, ohmeter, milliameter) from Harbor Freight for $3 and it is a pretty good instrument, I'm an EE and I have one! Follow my diagnostic procedure and stop randomly trying this that and the other thing and finally find out what is causing your no crank condition.
Old May 3, 2008 | 11:51 AM
jimmers's Avatar
jimmers
I checked the voltage at the clutch safety switch with someone cranking the car and got 11.4 volts. I did the same thing for ground and the starter like you said and got .3v for ground and 0v at the starter. My battery reads 12v so I put a battery charger on it. When turning the key to on, all the electronics in the car would start turning on and off on their own.
Old May 3, 2008 | 01:03 PM
jfb's Avatar
jfb
You have a dead battery. Car batteries are considered discharged at 12.0 volts. Your electronics goes crazy when the battery voltage gets low. Batteries are considered fully charged at 12.9 volts and above and linear in between. After charging, turn on your headlights and measure the battery voltage, it MUST be above 12.0 volts, fully charged it will read 12.9 v or higher.
Old May 3, 2008 | 01:15 PM
jimmers's Avatar
jimmers
Thanks for your help I really appreciate it. I took your advice and put a battery charger on the car. I'll let it sit for a few hours and hope that it starts. I did try a different battery a few days ago from my truck but the car never started. The needle on my battery charger says its 100%, but the needle seems to be jumping around alot which is strange. Forgive me because I'm far from an electrician, but could it be possible that I have some sort of short or wires pinched together that could cause the car not to start? The past few days my battery has never been 12.9v. Is it possible that somthing is draining it causing it never to be at 12.9. Boosting the car didn't work either. Sorry if they are dumb questions, I'm just trying to understand.
Old May 3, 2008 | 03:08 PM
jfb's Avatar
jfb
A brand new battery fully charged will read 12.9 volts, but the older they get the lower the voltage even fully charged. Your battery should easily read higher than 12.0 volts when you take it off the charger. Leave it on charge for as long as you can before you attempt a crank. Any wires in your car that are touching will blow a fuse, all circuits in your car are fused except the large cable going to the starter motor. Since you didn't measure the other battery, we cannot be sure it is ok and charged. Let us know what the battery voltage is with the headlights on after you finish charging it.
You could have excessive leakage current that discharges the battery. Don't let batteries sit for long periods (4+wks) without charging them. Car batteries become sulfated and become door stops when you don't keep them charged up.
Old May 3, 2008 | 04:06 PM
schrade's Avatar
schrade
Originally Posted by jimmers
To get right to the point, my car won't start. All the starter does is click. I took the starter out to get tested and it's fine. I have 12 volts at my starter and battery. I tried another battery for the heck of it but nothing. I don't have any codes and all fuses are good. Any ideas? Are the starter relays under the steering wheel? When I try to start the car they click a few times really fast. Is this normal? Thanks!
Have you tried jumpin' the solenoid?
EDIT......
Thanks for your reply! Do you mean just run jumper cables from the battery to the starter?
Yes.
EDIT2
Is there anyway to engage the starter straight from a 12v source outside of the car?
see above
Old May 3, 2008 | 04:13 PM
schrade's Avatar
schrade
That means that battery was bad (unless it works in another car. then you didn't do it right)
Have you tried jumping with your own battery?
Old May 3, 2008 | 04:18 PM
schrade's Avatar
schrade
I did try a different battery a few days ago from my truck but the car never started. .
Did you have your truck battery grounded to the vette's frame WITH ITS OWN CONNECTION?
Did you have the truck battery connected DIRECTLY TO THE STARTER 12V INPUT?
If yes to both, what happened?
Old May 3, 2008 | 06:47 PM
jimmers's Avatar
jimmers
The battery works fine in my truck, so I must of did somthing wrong.:o I did try jumping with my own battery but the starter just clicks.
Old May 3, 2008 | 06:49 PM
  #33
jimmers's Avatar
jimmers
I took the battery out of my truck and used the vette battery cables to try. I never tried the truck battery directly to the starter though.
Old May 3, 2008 | 06:50 PM
  #34
jimmers's Avatar
jimmers
I just checked the vette battery and it's at 12.4v. I'll wait till it reachs 12.9 volts then try and start it.
Old May 3, 2008 | 07:19 PM
  #35
jfb's Avatar
jfb
12.4 volts is 50% charged and should be fine for cranking. But you still need to measure the battery voltage during cranking and if it won't crank, measure the voltage from the neg batt terminal to ground and also from the positive batt terminal to the large bolt on the starter motor. There are more things a battery can fail at then just its state of charge and these measurements will point to the problem.
Old May 3, 2008 | 10:00 PM
  #36
jimmers's Avatar
jimmers
For the short period that I was at home I tried to crank the car. The starter didn't even make a sound and I couldn't even turn on the headlights. While cranking I had 6v at the battery. I didn't have time to test the ground and starter terminal.
Old May 3, 2008 | 10:24 PM
  #37
schrade's Avatar
schrade
Jump vette's cables.
Truck battery in vette.
Truck battery ground terminal to frame.
Truck battery positive terminal to starter 12Vinput. Connect cable clamp to starter 12V input, THEN, while not under vette, connect to positive terminal.
Start vette.
To Help car won't start!
Old May 4, 2008 | 12:15 AM
  #38
jfb's Avatar
jfb
You have a battery that is defective and cannot deliver even moderate amounts of current. You can install another battery from a vehicle that you know the battery is good for further testing. If with a known good battery that is charged up, if you still don't have cranking, then follow my diagnostic tests to find out if you have a good ground and a good positive cable to the starter motor. Both the ground cable and the positive cable should not have more than 1 volt drop across them during cranking.
The negative battery cable first goes to the frame and another braided wire goes from the frame to the left side of the engine. Starter motor current flows through the frame to engine block braided wire and if this wire is damaged or has a poor connection on either end, it will not pass enough current to allow the starter motor to crank. Measure the voltage from the neg batt terminal to the engine block while someone hits, "crank", position on the ign sw. You should not see more than 1 volt. Higher voltage and you must look carefully at the braided wire and the tightness and cleanliness of each end of the braided wire.
Old May 4, 2008 | 12:21 AM
  #39
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
JFB,
Any chance the ignition switch on the column is bad?
Ive read everything you suggested...I had a problem with the ignition switch going bad on another car,and it did the same things he described.
I mean,his lights arent even coming on and I had plenty of bad batteries that wouldnt start the car but let the lights an other functions still work somewhat.
Just wondering what you thought about that.
Old May 4, 2008 | 12:25 AM
  #40
jfb's Avatar
jfb
Yes, that is a possibility. If you jump 12v to the jumper wire on the clutch safety switch, that will bypass the ignition switch and the start enable relay and the starter solenoid should pull in and the starter should crank the engine. He could also have a defective fusible link supplying power to the ignition switch. Headlights are on a different set of ign sw contacts than the starter and his headlights won't turn on. But 6v at the battery tells me the battery is defective.
