LT1: which muffler do you use?
Old May 26, 2008 | 05:28 AM
DREGSZ's Avatar
DREGSZ
Default LT1: which muffler do you use?
Which aftermarket muffler do you use?
I'm looking for increased power but don't care if it is louder then stock, (although those elements seem to go hand in hand=)
I'm on a tight budget so low cost ideas are welcome.
Evan
Old May 26, 2008 | 08:04 AM
SAY WHEN's Avatar
SAY WHEN
Default Magnaflow
Rear mufflers only --stock cats and resonator--fairly quiet at cruising speeds---I personally like the sound under acceleration---sounds more like i think a Vette should---they are stainless--although I don't like the "polished shine" look from the rear and side view--I'll likely paint the mufflers flat black and leave the tips as they are---found them on ebay and i think they were around $356.00 to my house---some manufacturers have sites where you can "hear" what the system should sound like on your model of car--but it's hard to tell thru PC speakers--best if you know someone with a car like yours to hear what it will truly sound like I like mine-not to quiet -not to loud--but it's really personal preference'
Old May 26, 2008 | 08:18 AM
MTVette's Avatar
MTVette
CorvetteCentral's HOT ('high-output turbo') mufflers. The sound is great - see yt clip link in sig. Cost is not bad, too.
Old May 26, 2008 | 08:43 AM
1blkc4's Avatar
1blkc4
get rid of the mufflers, resonator and get straight pipes bent, thats probally your best value. i had mine done for 45 bucks.
Old May 26, 2008 | 08:44 AM
1blkc4's Avatar
1blkc4
Default exhaust
Old May 26, 2008 | 08:49 AM
aminnich's Avatar
aminnich
And sounds like this:
http://www.youtube.com/watch?v=OAReLmJLTlk
But don't expect any HP gains, the factory set-up is nearly perfect as far as HP goes. Long tube headers, hi flow cats, and and x-pipe will get you a little HP with the stock LT1, but not a lot without other mods.
Old May 26, 2008 | 04:12 PM
DREGSZ's Avatar
DREGSZ
Richard Newton says the stock cast manifolds flow better then aftermarkets but I can't believe that uncorking the mufflrs won't increase a little power
Old May 27, 2008 | 04:00 PM
93lt1fun's Avatar
93lt1fun
Default I like Power Effects adjustable mufflers
I like the Power Effects cat-back adjustable muffler system. I've had them for 10 years and they still work great! They have a six position adjustable cut-out that can be used all the way closed for full muffled sound to all the way open like a straight pipe or anywhere in between. Adjustment is easy from the side with a large aluminum dial. For more info go to:
http://www.powereffects.com/indexmain.html
Old May 27, 2008 | 04:24 PM
93lt1fun's Avatar
93lt1fun
Default Stree Pro Electric Exhaust Cut-Out
I just found this website as I was searching to see if anyone had developed an electric solenoid for exhaust cut-outs. This may be an option for you.
http://streetpro.us/index.html
For some reason Power Effects mufflers hasn't developed one of these although early in their advertising they claimed one was in development. I'm going to see if this one could be adapted or if they want to make a custom auto cut-out for the PE mufflers.
Old May 27, 2008 | 04:50 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've got muffler eliminators, but you can do it cheaper / better at a local shop.
For the blower engine, I bought a set of B&B's
Old May 27, 2008 | 06:04 PM
Gary04Z06's Avatar
Gary04Z06
What's a muffler?
Old May 27, 2008 | 06:49 PM
janarvae's Avatar
janarvae
Hm, that's you? I've watched that video a couple times on YouTube before....
Jonathan
Old May 27, 2008 | 08:31 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I use a Magnaflow Resonator with a X inside and Magnaflow SS 3" Mufflers all with Hooker Shorties.
Old May 27, 2008 | 09:37 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I've got Borla but its not load enough.
Old May 28, 2008 | 12:58 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Evan
Evan, just remove the stock mufflers and gain power from the weight savings. On the LT1 everything I've heard says that the stock exhaust is not restrictive until you are pushing 400 rwhp. Once your budget improves .... get a set of long tubes
Old May 28, 2008 | 06:19 PM
skybolt31's Avatar
skybolt31
Mine is stock. It is fine for me, my L98 had some resonance issues, but this car has none.
Old May 30, 2008 | 10:50 PM
95VETTEINMEMPHIS's Avatar
95VETTEINMEMPHIS
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-11-'12-'13
Sooner or later by not running some type of muffler you will burn a piston. Two guys in our club has done it.
To LT1: which muffler do you use?
Old May 30, 2008 | 11:12 PM
Andrew's Avatar
Andrew
I agree! I just bought a C4 with these mufflers and they are very nice, but you better like the car loud.
I've got LT headers, random cats, and 3" stainless tubes with the Power Effects mufflers. They also do not have that awful droning sound.
Old May 31, 2008 | 04:31 PM
rickneworleansla's Avatar
rickneworleansla
Old Jun 1, 2008 | 04:31 PM
93lt1fun's Avatar
93lt1fun
Running with mufflers only wasn't the sole cause for piston failure. However, running freer flowing exahaust is known to make the engine run leaner. So in addition to running without mufflers it might be a good idea to upsize the injectors. On a relatively stock motor you should be OK with 24lb like the Ford SVO's. Anymore mod's may require a bigger injector. I run 30lb with my 396.
