MAT Sensor???
Old Jun 12, 2008 | 11:33 PM
$300vett's Avatar
$300vett
Default MAT Sensor???
I am in the process of installing a new EGR valve on my 1985. When I removed the plenum I noticed the MAT sensor was not plugged in.. Well I can't seem to find the plug for it.. When I look at the connection on the plenum it was dirty like it has never been hooked up. I guess my ? is can it run without it.. It wasn't throwing any codes out...... The reason I was changing out the EGR valve is the engine lopes while idling... or would the missing MAT sensor cause the engine to lope???
Thanks $300vett
