96 No Start Problem
Old Jun 30, 2008 | 04:06 PM
ajd3rd's Avatar
ajd3rd
Default 96 No Start Problem
A friend of mine has a 96 with about 100k on it. The battery and starter are relatively new (within the last year). He recently drove it for a few minutes turned it off and then a few minutes later when he went to start it ..nothing. No crank, etc. He tried it a few times, still nothing and then he heard a clicking noise coming from passenger side of the car. He disconnected the negative battery cable and reconnected it. Then the car started no problem. My initial thought was a VATS problem, but what could cause the clicking noise? It wasn't the starter and was clicking with the key out of the ignition switch. It continues to start ok now but we're concerned it may not be reliable.
Any ideas are greatly appreciated.
Old Jun 30, 2008 | 04:24 PM
jfb's Avatar
jfb
There isn't enough information to determine the exact cause of the no crank, BUT, I believe the clicking was from the anti-theft circuit relay preventing the no crank. Disconnecting the battery cable allows a reset of the anti-theft circuit and until the anti-theft circuit acts up again, I believe the car will start reliably.
Old Jun 30, 2008 | 05:04 PM
ajd3rd's Avatar
ajd3rd
I assume the relay is part of the VATS system. I'll take a look at the manual tonight to see where it's located. Thanks for your help.
Old Jun 30, 2008 | 08:01 PM
jfb's Avatar
jfb
It wouldn't be the VATS relay that was clicking, it would have to be the anti-theft relay.
To 96 No Start Problem
