1990 distributor help!!!!
Old Jul 25, 2008 | 12:21 AM
excessive81's Avatar
excessive81
Default 1990 distributor help!!!!
okay this has been going on for severl months and i am stumped. i have a 1990 l98 with hei distributor. the car will not start. i have tried a complete distributor and still the same so have went back to the old one with all new internals.... coil pick up, coil, modual, condensor cap and rotor all new. there is correct voltage at the battery terminal of the distributor when the ignition on. i got a spark testor and there is a very small spark (10 1/8th in on the scale that says it should be 30-34 1/2-3/4 in) coil tests ok as well as the modual still. only thing i can see that is diffrent is the condensor of the replacement distributor i bought was a old school looking tube unit as well as the new one i bought. but the one that was in the car looks is a red chip type. i dont see how this could be the problem as when parts stores look it up they all hand me the round tube type. so........... i am lost and missing races every weekend any ideas what next?
Old Jul 25, 2008 | 01:25 AM
cwyates4's Avatar
cwyates4
I wonder if your car would fire up if you disconnect the electronic spark timing wire...
You wouldn't be off 180, would you?
Old Jul 25, 2008 | 09:02 AM
rodj's Avatar
rodj
That is only part of the system. Spark is controlled by the ECM. Possible damaged wiring to ECM
Read this , for 86 but same basic spark system.
Pg 5 has fault finding chart.
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old Jul 25, 2008 | 09:33 AM
excessive81
no it not 180 out...tried that to. and have done most the items on that list on page 5. will double check it today
Old Jul 28, 2008 | 09:17 AM
excessive81
ttt
Old Jul 28, 2008 | 08:47 PM
rodj's Avatar
rodj
May be time to look outside dist if same results with spare one..
Can you smell fuel out exh when cranking?
'90 has CCM; data link to the ECM .Runs a self check on non engine functions.If it sees a fault it may throw a code or for some systems cuts the injector driver meaning no fuel.
Fault with the airbags (SIR ) for instance will shut it down.For instance bad earth on SIR motion sensors is common problem .
Do you have any codes stored?
Old Jul 29, 2008 | 10:30 PM
engle1147's Avatar
engle1147
Don't worry about the "tube" style condensor I've got one just like like it and it works fine. You say you have spark - right. When you crank the car watch the RPM gage in the car if it moves when the car is being cranked look for problems elsewhere....you may need to crank it for more that 30 seconds.
Good Luck!
Old Jul 30, 2008 | 01:33 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Just for grins, disconnect the battery for 3 minutes, and see what happens when you reconnect it. (It should start, not blow up)
If that doesn't fix things, try putting in a paper clip in a+b of the ALDL connector.
I had reset the computer just plugging in the paper clip and watching it go through 12 12 12 12 then bing! it reset.
Old Jul 30, 2008 | 07:40 AM
KeyWestJack's Avatar
KeyWestJack
Old Aug 10, 2008 | 10:22 PM
jam019's Avatar
jam019
Originally Posted by KeyWestJack
Vats system, maybe
To 1990 distributor help!!!!
