I am working on a GS that has F45. We are wanting to put a non adjustable set of shocks on the car for autocrossing. If I disconnect the shock and leave the electronic connection unhooked will it throw a code and if so will it hurt anything? Is there a device to fool the computer?
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Yes, it should "throw a code", albeit only the 'selective ride' computer (not the PCM/BCM 'check engine' light -- just the 'selective ride' light(s) on the DIC. You can just ignore the lights (or remove the bulbs if a long-term situation).
Would recommend unplugging and removing the shock actuators (motors on top of shock), and storing them with the shocks (as they are valuable and the next owner might want them back), and taping the connector to prevent water intrusion and a short (which could damage the selective ride computer).
There are no motors on top of the F45 shocks. They are different than the earlier FX3 shocks.
It will throw a code and turn on the dash light but it won't hurt a thing.
Before you change the shocks, you may want to try the car first with the solenoids unplugged. The shocks are designed to be in the firmest setting with no power applied to the solenoids. The damping in the firm setting is quite a bit stiffer than most aftermarket performance shocks.
I know it seems like the F45 shocks don't have enough damping for track/autocross work, but keep in mind that under most operating conditions, the control algorithm will never command full damping.
