Ran out of gas, Now check engine light is now on???
Will the light go off by itself or what? Please help.....Also, I was only 1 mile away from the station...
Don't just
remove the positive cable, if it touches somewhere and inadvertently grounds you can do much damage and will get a fireworks show...
always remove the negative cable first, then the positive cable, and reconnect in reverse order...good luck
