Hyperco (Hypercoil) C4 performance leaf springs
Old Oct 30, 2008 | 11:44 AM
89FX3's Avatar
89FX3
Default Hyperco (Hypercoil) C4 composite performance leaf springs
Just ordered a set for each Vette:
http://www.hypercoils.com/Corvette/
Anyone else have these?
Old Oct 30, 2008 | 11:48 AM
StealthLT4's Avatar
StealthLT4
Hmm, never heard of them. Let us know how it works out!
Old Oct 30, 2008 | 12:38 PM
89FX3's Avatar
89FX3
Default Hyperco is what Van Steel sells...
http://www.vansteel.com/index.cfm?fu...&SubGroup=1950
A thread was posted by Van Steel when they were introduced in 2007 but I haven't seen any follow up postings.
The springs are offered in several different rates including one based on the Corvette Challenge series.
I'd like to hear back from people who've installed them, and how they compare to coilovers.
Old Oct 30, 2008 | 12:42 PM
89FX3's Avatar
89FX3
Here's a description from Van Steel's web site:
"The front Hi-Performance Springs are specifically designed to for autocrossing and/or improving track time. Increasing the spring rate on the front spring dramatically reduces nose dive under hard braking and improves the handling by controlling weight transfer. Ride qualities are not compromised with the increased rate.
The rear springs are disigned for drag racing, autocross racing or track time use. Increasing the rear spring rate allows you to control excessive weight transfer while cornering and reduces the squatting coming out of turns or launching when drag racing. "
Old Oct 30, 2008 | 12:43 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I know Hyperco coil springs have a very very good reputation, so I am thinking their leaf springs would be up to their quality.
Only time will tell.
Old Oct 30, 2008 | 02:51 PM
ekess744's Avatar
ekess744
"Increasing the spring rate on the front spring dramatically reduces nose dive under hard braking... "
and with out changing the brake bias rearward, would equate to less weight transfer to the tires doing the braking
Old Oct 30, 2008 | 03:57 PM
rklessdriver's Avatar
rklessdriver
We have run them on our oval track cars.
The BEST leafs I have ever used came from LANDRUM thou.
Will
Old Oct 30, 2008 | 04:26 PM
Aardwolf's Avatar
Aardwolf
I'd be curious how much they drop (or don't) your lap times. I've put off new springs but would like some one day. They are much more expensive then sway bars which I am thinking is my next mod.
Old Oct 30, 2008 | 05:30 PM
10.5Vette's Avatar
10.5Vette
I ran Hyperco springs on my 95 Trans-Am I used as a daily driver/autocross car and they worked great. Also lowered the car about 1.25". Wonder if these lower the ride height also, or keep it stock??
Old Oct 30, 2008 | 06:03 PM
StealthLT4's Avatar
StealthLT4
Leaf springs are always so expensive ... for the cost of nice shocks and new springs, you can get one of the nice drop-in coilover conversions! Ack!
Old Oct 31, 2008 | 10:44 AM
89FX3's Avatar
89FX3
Since you can pick up a set of the Hyperco leaf springs from Van Steel for just over $600 (assuming 10% CF discount), and then put on a set of QA1's for around $550, it seemed to me to be a cost effective alternative to converting to Penske or similar coilover setups.
Plus it doesn't present the coilover conversion issues I've read about on this forum.
Old Oct 31, 2008 | 10:47 AM
89FX3's Avatar
89FX3
According to Van Steel's web site, the "track" ones do just that.
Old Oct 31, 2008 | 11:44 AM
ekess744's Avatar
ekess744
The suspension as system must matched and balanced to to grip levels and alignments for optimal performance. I don't run street tires anymore, except when Im feeling cheap but there is a huge difference tire width/compounds compared to grip levels...
Old Oct 31, 2008 | 05:09 PM
96GS#007's Avatar
96GS#007
I have their Z51 front spring (was able to get an OEM '90 Z51 rear). The spring is every bit as good as advertised and maybe better. Fantastic quality, perfect fit.
I use my car for HPDEs and based on in-car video analysis, it's clear my lap times improved (I did the springs and a 30mm front sway bar at the same time, nothing else).
Old Oct 31, 2008 | 05:17 PM
Aurora40's Avatar
Aurora40
It's weird no one seems to advertise spring rates? I tried to get that info from VB&P also and never got any reply.
Old Oct 31, 2008 | 07:42 PM
DBall's Avatar
DBall
I spoke with their sales rep. They basically are the the same rate as the Z-51 springs from 1990. (Front and rear) I have a used set I am selling also. Not stiff enough for me so I went to VBP and spoke with Gary . Good deal.
Old Oct 31, 2008 | 08:16 PM
Aardwolf's Avatar
Aardwolf
I've been getting some serious body roll!
To Hyperco (Hypercoil) C4 performance leaf springs
Old Nov 1, 2008 | 12:00 PM
ekess744's Avatar
ekess744
what tires?
Old Nov 1, 2008 | 12:59 PM
JimiHendrix's Avatar
JimiHendrix
Isn't body roll controlled by the thickness of sway bar? You can have a soft spring and good roll control with the proper sway bar....no?
Old Nov 1, 2008 | 01:35 PM
Aardwolf's Avatar
Aardwolf
Yes, though a better spring would help with braking nose dive too. I usually pick up used street tires to destroy at the track. There are KDW on there now.
