Sound Dampening and Audio Upgrade Project (LOTS of Pics **No 56k**)
Here's a better pic showing the Ensolite on the tunnel and the Luxury Liner Pro on the floorboard
Eventually I'll wrap all the power cable and other audio cables with this black stuff, it's called tech flex
I like it! I don't understand the benafit of the black layers though??? Mine is sitting with an almost identical layer of dynomat and a layer of (???can't remember the name???) foil covered insulation and i am already having problems getting a new carpet set over. Any idea what i am doing wrong?
Please keep this updated.
I have to agree !! I'm planning on doing some work to my interior over the winter But I doubt I can imagine i'll be going to nearly that extent ! Great job Really looking forward to the end result !
btw how much to fly you to Toronto to do my car
I got a little further on the glassing, I'm almost done with the mat and going to start putting on the weave. After that the MDF ring gets hot glued in then fleece is draped over to contour the shape of the car and then glassed.
ahh
is that it for the pictures? I was really enjoying that. I wanted to see the fiberglass being poured. Please take lots of pictures and post them because im doing the same to my car right now.
I'm still taking pics, right now I decided to make the amps completely flush with the false floor so I trimmed the fiberglass a little in the pic below. The floor will be about 3/4 inch lower, then I'll just fiberglass over it to make the two surfaces flush. I can't really take pics of pouring the resin, I use another method. You use disposable paint brushes and add a light coat of resin so the fiberglass can stick then paint the fiberglass with more resin until is gets clear (goes from white to clear). That's about it really. If you've never done it you'll get the hang of it very fast.
Here is the new cover I'm making that will be flush with the amps. Right now the amps sit on a false floor that is raised about 3/4 inch so the power wires can go underneath, then this new piece goes on top of that.
Old
New
Old
New
#33
Here's the panel for the amps I redid to make it flush with the amps, I think it looks much better.
#38
Wow! Hope you bagged and tagged all the hardware you took out of that bad boy......I recommend using thread tape on all that fastener hardware when it goes back in or else that stereo system you got going on there might shake it all loose again...j/k I can smell the resin from here.....keep up the good work.
It is lookin' awesome! Don't forget to post the "finished" set of pics.
#40
Now it's back to where it was before I lowered the floor, just a few more pieces of mat left to be put on then I'll start with the weave.
