Best replacement cam for an 85/L98
I ran the cam Master shake posted earlier,years back in my 86.It ran great,idles good with excellent vacuum.Heres the cam again..no prom was needed but cant hurt to upgrade either.
http://store.summitracing.com/partde...2&autoview=sku
You should take the advice from Aggrevated4Life before mine. Besides, it's not worth agonizing over. Any of the cams mentioned in this thread are probably good choices...especially compared to the one that's in there now.
BTW, I don't recall what your rear end ratio is. The more duration you go for, the more you'll need the 3.07 performance gear ratio.
Finally, about a gajillion years ago I was advised that in the case of indecision, it's better to go conservative than wild.
Best of luck in your decision
Thanks for the additional input Aggravated4life and Corvette Bob.
I do have the 3.07, so that is taken care of..
BTW Corvette Bob, the rear stance photo of your car with the wide wheels and tires look great..
I don't want to be radical..But I would like a nice "gated" idle. The best sounding idle I remember was a 69-Z28 with a 307 I think.. Ideals?
Number 1 cylinder cam lobe has worn down to the point the engine was backfiring into the intake.. Just recently rebuild engine ..Cam tolerances was fine then. Re-did heads and replaced lifters, and etc.. But now I will need a new cam and lifters again.. Improper break-in? Harder lifters? Not lubed properly? Just not sure...
What is your recommendations for a new cam..???
I also have the 3.07 rear end, so my road rpm's is approx. 1800..
I have nothing valuable to add but your mention of the 69' 302 grind brings back memories. I used this part # in a 327 RS camaro rebuild and it had a perfect sounding idle
Received 3,043 Likes
St. Jude Donor '05
Nothing better than the clatter of a solid flat tappet...Even rollers dont sound that good.
Had a 70 Z28 wiht a little larger than stock solid and man I NEVER got tired of listening to that thing run. Good stuff
1 Post
This cam kit is basically the same camshaft stated by summit, with a set of lifters included. Same RPM range, same duration, and just a couple digits less for lift. It's cheaper than buying the cam and lifters seperate.
The only real difference is that the LSA is 110 instead of 112, so it may not be as easy to dial in as the other camshaft, but I'm sure it will run fine with the stock ECU.
Well, I guess I lied.. I didn't place the order today.. Will not be shipped until Monday anyway..
I know this is old informatin for those that have been helping, but just in case, I'm still looking at these 3:
Lunati Part Number: 60101LK
Advertised Duration (Int/Exh): 256/262
Duration @ .050 (Int/Exh): 213/219
Gross Valve Lift (Int/Exh): .454/.468
RPM Range: 1000-5500
LSA/ICL: 112/108
Crane #270-114132
PowerMax Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .440''/.454''
Duration: 270°/276°
RPM Range: 1600-5400
C.A.R.B. Approved*
LSA 114
Comp Cams #249-CL12-256-4
Xtreme Energy Hydraulic Flat Tappet Camshaft and Lifter Kit
Lift: .449''/.456''
Duration: 256/268
RPM Range: 1200-5200
LSA 112
The Crane is the only cam that specifically states it is make for the stock set up with computer, springs etc.. But does suggest buying an adjustable fuel pressure regulator?
The Lunati says should work "in most cases" with stock springs.. In which cases would it not work?
Comp Cam doesn't really address any of those issues, but factory rep. said it "should" work with tight springs..
Still contemplating....
LSA/ICL: 112/108
Crane #270-114132
Lift: .440''/.454''
Duration: 270°/276°
C.A.R.B. Approved*
LSA 114
Lift: .449''/.456''
Duration: 256/268
LSA 112
It looks like you're on the right track w/ cam choices. The other guys may have better info than I do, but here are some thoughts.
As far as the stock computer goes, my hi-mileage brain thinks you're gonna be ok. Over the past several years there has been several guys that have put in some pretty good cams and they ran pretty good w/ the stock computer. For instance, a racer north of Cols.,Ohio used the GM LT4 hotcam (218*i,228*e@.050) in an '88 with 4+3, and it ran fine. There are also reports of using the ZZ4 cam (208*i,221*e) with few, if any, issues. These two cams have 112lsa if I'm mistaken. For a
stock tune, or any tune not done on a dyno, I wouldn't be too comfortable any more narrow than that. Besides, it's my understanding
that the lower the lsa number, the crummier the gas mileage.
BTW, the ZZ4 cam might not be a bad choice IF you go roller. Consider your needs when doing your research. The reasons above are why I like the Comp grind you're considering. I like Comp as they have a more ongoing R&D than the GM or Crane offerings.
If you're already running aftermarket springs, compare their specs with what's required for the new stick you choose. If they're OEM's I'd definitely suggest changing springs regardless of the cam you choose. The OEM TPI springs are only good to 5k, and that's when they were new. Couple that w/ the fact that they were supplied by the lowest bidder for about $1 or less each, over 20 years ago, and there's a good reason to upgrade springs.
Lastly, I have NO EXPERIENCE with the Lunati offerings. BUT, as I comb thru the Jeg's and Summit catalogs, there are a number of cam "manufacturers" that have grinds that closely mirror the Crane items. In my opinion, these "manufacturers" are more likely camshaft
"rebranders" that get them in a white box, then slap labels on those boxes.
I hope I'm not throwing too much confusion into the mix, but having had to make these choices in the past, I can recall what you're going thru in the selection process. Again, best of luck in your choice.
Finally a decision on the cam/lifter kit!!
Finally I made a decision..
I ordered the Crane 114132 and lifter kit from Jegs..approx..$182 shipped.
I really wanted to feel good about the Comp Cams or the Lunati, but just couldn't get enough information to do so.. I just don't have enough experience to fill in the gaps..
What I did find on the internet searches over and over, were references to success and satisfaction with the 114132. SO that's the primary reason I went with the 114132..
I very much appreciate all the input and time everyone has taken to help me. I will let you know what the out come is..
1 Post
Well it seems you made your choice and, as the LSA shows, it may be the best for the stock ECU. Whether you choose CompCams, Crane, Lunati, Edelbrock, Crower, or even Summit, they are all proven street/strip cams. Some swear by CompCams, others by Crane or even Isky but, for your extremely mild street application, I think you made the best conservative choice.
Let us know how it turns out.
Thank you Master__Shake,
It should not go unnoticed that the Crane was one of your first suggestions..And the 114 LSA did play a major role in the choice..
#33
For what it's worth...
I also think you made a pretty good choice. Although I'm not fond of Crane's products, they've obviously been doing something right all this time or they wouldn't still be in business. The 114 LSA will also give you that compatibility you're looking for. One of the important considerations to make on anything like this is your own comfort level. You seem to have comfort with Crane so you're on your way.
#34
The Crane Cam is finally in!
Well it only took about three months but the cam is in..Many you ask that I post results so here it is..
Much better than before..smoother engine during open road cruising and gas mileage improvement.. Old average was about 18.5, now about 21..
Take-off torque has a noticeable improvement.
Idle has a nice lope, (but still have a idle wander problem I haven't chased down yet..seems to improve when the engine warms up)
More than anything else the engine just seems to "hit" harder and exhaust is louder, even though I didn't change anything..
Thanks for all the input..
#35
Received 1,400 Likes
The idle wandering is in part because of the tune for open loop operation. That cam is just big enough that a chip change would help you, conversely its small enough that you can get by without it.
If you want it to run perfectly, have the chip redone. I would wait until a few other mods are done to take full advantage of the capabilities of the camshaft however.
#37
I also have been going back and forth with cam selection and was steered in the direction of the crane compucams which seemed very mild to me. I looked at the Comp Cam line and came across this one which is lissted as computer compatible
http://store.summitracing.com/partde...4&autoview=sku
These also are listed as computer compatible http://store.summitracing.com/egnsea...4&autoview=sku
#38
#39
#40
WTB: lt1 fuel rail, and a few misc parts
Hi, as the title states; im looking for a good lt1 fuel rail preferably with good injectors. Also looking for a 86-89 ecm. And the gold zf6 black tag or t56. Im located in northern indiana. I listed needed items in order of greatest need
