1991 eprom replacements??
Old Dec 9, 2008 | 07:35 PM
donb12257's Avatar
donb12257
2nd Gear
Default 1991 eprom replacements??
need badly , can anyone tell where to buy a replacement eprom ? 1991 6 spd coupe. dead until i can find one.
Old Dec 9, 2008 | 10:32 PM
Jim McCombe's Avatar
Jim McCombe
I took this from a previous post on this same subject.
Not sure if it will be of any use to you..
11-10-2008, 11:03 AM #1
spinner000
Junior Member
My Corvette Photos
Hello to all.
I posted a thread almost a month and a half ago regarding what I thought was a fuel pump problem Thanks for all your advice, however my baby is still not working. I have recently come to the understanding that there is a problem with the connections between the ECM and the ALDL connector. So I replaced the ECM with a remanufactured one and still nothing. Now I have to replace the PROM chip and as most of you probably know GM has since discontinued parts for a 1991 Corvette. I've researched it and come to the conclusion that I must either get and aftermarket one or one from a salvage yard. The only aftermarket one I've found is The Hypertech Powerchip at http://www.mamotorworks.com/corvette-3-139-847.html What are your opinions on this chip and would it work like factory. Or should I just get a used one.
Thanks.
spinner000
View Public Profile
Send a private message to spinner000
Find More Posts by spinner000
11-12-2008, 07:14 AM #2
rons85
CF Senior Member
My Corvette Photos
What happened to the PROM and Calpak from your Old ECM? Supposed to swap that over to the replacement, which (as you now know) doesn't come with them...
In any case - do you have the Calpak? You need that as well as the prom.
The Hypertec chip isn't significantly different from an OEM, just a few changes that really don't so much for you if it was increased Power you were looking for, but as a "replacement" for a stock chip it would be fine.
rons85
View Public Profile
Send a private message to rons85
Find More Posts by rons85
11-15-2008, 12:32 AM #3
spinner000
Junior Member
My Corvette Photos
yeah i moved over the prom to the new ecm but not the cal pack would the new one come with one. And I was told that it was my prom because although it has a new ecm the genisys cannot connect to the computer to tell me whats wrong with the car so they assume that the chip has gone bad.
