94 C4 - Wont Start
Old Jan 18, 2009 | 11:01 AM
rg951's Avatar
rg951
Default 94 C4 - Wont Start
I drove my car apprx 40 miles to work. Ran fine, no problems. I parked it, came back 8 hours later, & no start. It cranked over fine, just wouldn't fire up. After trying it for a few minutes, it seemed like it wanted to start at the end of the cycle. It would 'diesel' a little bit. At this point I could smell fuel & figured it was flooded. I borrowed a friends car, & went home.
What bothers me is I haven't driven it much lately & the day I drove it, it ran fine & being in So Cal, it was a nice day. When I pulled it in to park, it was running fine, no issues, no nothing.
Any suggestions? Being that it's a Sunday, I can't get anyone to look at it & hopefully it doesn't get towed. I am hoping when I go in today that for some grace of god, it fires up.
At this point, since I don't drive it much, it may be time to sell this thing & walk away. I liked seeing it parked in my garage, but if it's going to leave me stranded somewhere, thats not going to work either. Especially 40 miles from home.
Old Jan 18, 2009 | 11:05 AM
engle1147's Avatar
engle1147
Get a hold of timing light and clamp the pickup around the plug wires to see if your opti is sending spark to all the plugs.
Old Jan 18, 2009 | 11:11 AM
toptechx6's Avatar
toptechx6
You could have a leaking fuel injector that stuck open allowing the engine to flood, another possibility would be a leaking fuel pressure regulator. If you suspect it is flooded try cranking it with the gas pedal held to the floor, that will prevent the injectors from firing and adding additional fuel, (clear flood mode) of course if it starts immediately release the accelerator to keep it from over revving. That may allow you to get it somewhere for real diagnosis because it could also be weak spark or other issues, good luck.
Old Jan 18, 2009 | 11:50 AM
jsls0130's Avatar
jsls0130
I read a post the other day that kinda sounded the same, and his gas gauge had stopped working. He put fuel in his car and it started up. Just a thought.
Old Jan 18, 2009 | 12:02 PM
rg951's Avatar
rg951
I know I have a full tank of gas. I filled it up a week ago before I parked it.
In regards to it being flooded....I'm 99% sure as I can easily smell the gas. I didn't hold my foot down until after a few minutes of trying to crank it over. My friend walked over & suggested I try it. When I did, it was trying to start.
The opti-spark is brand new. Last year I put in a new opti-spark, wires & plugs. I doubt that I even had put 2,000 miles on it since then. I used to work 5 miles from work & own two motorcycles. Because the cost of gas was on the rise last year, I mainly drove the motorcycles & about every two weeks, would drive the Corvette.
Old Jan 18, 2009 | 02:11 PM
rg951's Avatar
rg951
Well, went to go start & it cranks over fine, but no ignition. It did try to kick over, but nothing. It backfired through the intake (a small poof) & it def. is getting fuel.
From here I have no clue & will have to call somone to take a look at it. The plugs at this point are probably done with.
Old Jan 18, 2009 | 02:15 PM
engle1147's Avatar
engle1147
Did you check the car for stored trouble codes?
Old Jan 18, 2009 | 02:18 PM
joecarter85's Avatar
joecarter85
Possabilities include:
-ICM
-Coil
-Coil wire to Opti
The above assumes that Opti is OK, as well as your FP and FPR.
Old Jan 18, 2009 | 03:31 PM
rg951's Avatar
rg951
I haven't checked for stored codes. I guess that I would have to break out a paper clip & remember which 'holes' to stick it in.
I guess the big thing that makes no sense is the car has been 100% ok. I pulled up & parked it. I would have never guessed it just wouldn't start back up. All the ignition components are new after destroying my opti last year by accident. I had no ignition problems recently or yesterday when I drove it.
Old Jan 18, 2009 | 05:44 PM
rayosequis's Avatar
rayosequis
My ICM went out while I was driving and acted just like yours did after it died. Why not just buy a coil and ICM from any auto parts store and plug them in and see if it starts. If your very careful about how you handle them, you should be able to return them if it doesn't work.
Old Jan 19, 2009 | 09:54 PM
jsls0130's Avatar
jsls0130
Have you had any luck getting your Vette running? Just curious.
Old Jan 20, 2009 | 11:51 AM
rg951's Avatar
rg951
Well, I'm pretty mechanical but the car is about 40 miles from where I live. Down the road where the car is I had a garage work on it last year rebuilding the heads. They picked it up yesterday afternoon & I'm waiting to see what they say.
He didn't seemed too concerned as I explained to him what was wrong. It's obviously a spark problem or fuel problem. I would assume it's not a fuel problem as I think it's getting plenty of gas & I'm pretty sure it flooded. The weird thing though when the flat bed came & picked it up, fuel was leaking on the ground by the tank. It wasn't alot, but I wonder if it was from all the 'cranking over'.
Maybe the fuel pump took a dump? I don't know.
Old Jan 20, 2009 | 06:42 PM
Nathan Plemons's Avatar
Nathan Plemons
Well, you shouldn't have fuel leaking out of the tank area under any circumstances. It's possible that the fuel actually came out of the tail pipe from where it was getting fuel but no spark to ignite it.
You need to go to the basics, fuel and spark. You know you're getting fuel, but are you getting the right amount at the right time? Check your fuel pressure. If all your injectors are working fine it should pressurize and hold that pressure for hours. If it drops quickly, you have a leaking injector which can be flooding that cylinder and starving your other cyclinders of the fuel they need.
More likely, however, I'm betting on spark. I had a brand new opti crap out, but it wasn't actually the opti, it was the connector that connects the opti to the wiring harness. It corroded and stopped making contact. Without this, the engine had no idea when to fire so it didn't. It could also be your ICM or your coil. These are parts with no moving components, so when they die, they die suddenly. Check for spark and see what you've got. Although you hate to "throw parts at it." It would be worth replacing the coil and the ICM before you tear into the opti just because these are very easy to do.
Old Jan 20, 2009 | 09:28 PM
rg951's Avatar
rg951
The Opti I have in it is an MSD. I got it last year & so far about 2,100 miles on it. Last year I only worked 5 miles from home & I have 2 motorcycles. So, every week or two I would take it out for a spin.
I believe the fuel leaking was probably coming from the exhaust pipe. Since it was on the flatbed, It was hard to see where it was leaking. The car was being pulled up when it leaked. At that point I saw the wet spot it was by the tank but most likely was coming front.
I called the mechanic working on it today but he didn't have alot of time to look at it as he needed an open bay. He confirmed the fuel pressure seemed good & will be looking for spark or lack of.
Old Jan 22, 2009 | 01:09 AM
RogerZ06's Avatar
RogerZ06
What my car did when msd cap on optispark went out
Old Jan 22, 2009 | 10:32 AM
rg951's Avatar
rg951
What went wrong on the cap & what did you do to fix it?
Old Jan 22, 2009 | 12:08 PM
RogerZ06's Avatar
RogerZ06
Oh I had little black ball on cap jump off. I sent it back to msd they refurbished it.
This could be your problem or could not ? Just the problem I had. Also check your codes to see if you got H16 or H36.
To 94 C4 - Wont Start
Old Jan 22, 2009 | 01:10 PM
rg951's Avatar
rg951
Did your car shut off during operation or did it not start like mine did?
I guess the other possibility could be a loose rotor?
What was the little black ball that jumped off your cap?
Old Jan 22, 2009 | 04:35 PM
RogerZ06's Avatar
RogerZ06
It only didn't start when I let my car sit for weekend. Before that I had hard starts for week.
Little black ball was part of connections for cap or something.
Old Jan 22, 2009 | 08:41 PM
rg951's Avatar
rg951
Well, talked to mechanic today & he confirmed that the fuel is good. The pressure & injectors checked out. He ran out of time today but is going to tackle the coil, ICM, & distributor tomorrow as he feels it's 1 of the 3.
