Success! Transplanting a '92 LT1 Instrument Cluster in a '91 L98! Pics inside
I have had a few tachs and the first one was off by a few hundred rpm. a different one cured it. Did you try just plugging in the new tach to see if it was still off?
I didnt know there was a difference between the l98/Lt1 tachs
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Cool Thread! Good job!
Which tachs have the 7K mark on them? Are they just ZR1s, and do they plug in just the same way?
Will a 94 one work? I got a lead on one but the seller said it was 94-96
Well, if you have a '90 or '91, you may want to stay within the color scheme of your year. The '92 and '93 LT1 instrument clusters and AC/stereo buttons still had the orange lettering. In '94, the lettering and gauges started using white lettering. I imagine a '94 would be plug and play too. The color difference was what made me choose a '92/'93 cluster.
There is a difference between the L98 and LT1 tachs! Check out the pictures above. The L98 was a lower revving engine than the LT1. So the LT1 hits the hash/redline marks at 5500, instead of the L98's 5000. The gauges also have more ticks or deviations, making them MUCH easier to read. Additionally, the LCD in the L98 displays the MPH on the bottom and fuel level on the top. The LT1 LCD displays the MPH on the TOP and the fuel on the bottom.
I know for sure the '91 ZR-1 has an 8,000 RPM tachometer. Someone in this thread said they just installed a ZR-1 tach in theirs.
Besides the ZR1s, the LT4 also had an 8k tach, I believe.
I did have to swap LCDs in mine as the ZR1 cluster I bought from a forum member had a bad LCD (I knew this when I bought it). The LCD from my L98 panel plugged right in and worked perfectly.
How did you make sure the tach is reading right?
Thanks! I am building a SB 408 on the side and it should have a redline of around 6,500 RPM but I want the interior to look stock and not have aftermarket gauges. I dont think it would look right.
2 more to go if you don't care about the color scheme.
I have a question. You said that you cleaned all of the contacts in the dash and on the new cluster. Do you think that this fact alone could be the reason that the new cluster is working correctly? That cleaning the old clusters contacts and reinstalling it would bring the same results?
Randy
Randy
#34
Randy
Randy
-Jonathan
#35
I don't know how to bench test it. I tested it after it was in the car. It would not take much time to remove it if it didn't work as planned.
#36
It would help if I didn't get a woody when I saw the cluster for $99.99 and bought it on ebay. IT is on the way here so I have to make it work as much as possible.
#38
Anyone know how to bench test a cluster?
#39
Bummer
Got the thing today. Well, some of the warning lights like the Door Ajar is not in the right spot. For instance, the Door Ajar on the 91 is on the extreme right. On the 94, it is brake pressure. Guess I will have to sell it or trade it towards a fix.
#40
Now, if this is the excuse you need to get an orange one, then, right on!
