swapping computer ?s
Old Mar 10, 2009 | 10:40 PM
nlk2005's Avatar
nlk2005
Default swapping computer ?s
I have a 92 vette. Wondering if anyone has put a newer computer from a 95 into the 92 in order to use PCM mail order tunes since they arent available for the older chips. I really dont want to go through the hassle of getting data writers and erasers as stated in the sticky tuning thread
Old Mar 10, 2009 | 10:48 PM
STL94LT1's Avatar
STL94LT1
No won't work.
Old Mar 10, 2009 | 10:50 PM
nlk2005's Avatar
nlk2005
damn...thanks
Old Mar 11, 2009 | 10:30 PM
DVNCI's Avatar
DVNCI
If you REALLY love your car you could get the harness as well so that you could use the 94/95 PCM, that's the only way it will work, with another harness. I'm putting a Painless 60505 in my 96' right now (for other reasons)
Old Mar 11, 2009 | 10:40 PM
STL94LT1's Avatar
STL94LT1
Also, the 94/95 PCM contolls the e. trans, MAF, and sequential port fuel injection. All of which the 92 doesn't have.
Old Mar 12, 2009 | 05:38 AM
nlk2005's Avatar
nlk2005
that is the question i was originally asking, my fault for not being specific enough. so it will work by swapping the whole harness then that makes me all tingly inside
Old Mar 12, 2009 | 06:37 AM
LD85's Avatar
LD85
Call Jim he will help you if he can,
www.jimsperformance.com
Old Mar 12, 2009 | 07:25 AM
djxib's Avatar
djxib
I am running a mail order tune in my 92.....
Old Mar 12, 2009 | 07:41 AM
anesthes's Avatar
anesthes
Ehh.. BCM might error.
Some things won't work right.
The 92+ cars, wiring is a disaster. Too much work, and it will never be right.
1992 = $DA2 binary, which you can get a mail order or you can get an emulator and tune real time.
-- Joe
Old Mar 12, 2009 | 08:27 AM
Tom Piper's Avatar
Tom Piper
I looked into this in detail -- if the search works, you will find it.
There are a lot of things to consider -- in the end, the best way was to sell the '92 and buy the '95....probably a lot cheaper too.
Tom Piper
Old Mar 12, 2009 | 09:19 AM
DVNCI's Avatar
DVNCI
Yes, check out the Painless 60502/60505, that will do it.
-- Joe
You probably will get a CCM error but everything should work fine, I had a 95 PCM w/ a 96 CCM and I did get the blinking SYS but everything worked perfect. I have completely gotten rid of the PITA CCM though, worst thing ever (for me anyway).
Tom Piper
All the above being said, you can make this work, but I would have to say I probably agree with Tom for the most part. No telling what problems you'll run into, the CCM is really the biggest problem, CCM controls pretty much freaking everything other than the engine, which is why I have gotten rid of mine and I'm just using a regular Street Rod harness for everything. Car will be FAR simpler now from a wiring perspective. But that's pretty extreme for most!
Old Mar 12, 2009 | 10:30 AM
anesthes's Avatar
anesthes
How does your speedometer work?
I was going to do a '91+ dash swap, but the CCM end of it turned me off. If the '91+ dash had a mechanical odometer it would have been great.
-- Joe
Old Mar 12, 2009 | 01:11 PM
DVNCI's Avatar
DVNCI
-- Joe
Now or before?
My car is a 96' but when I was running with a 95' PCM ALL the CCM stuff worked perfectly, other than the blinking SYS light. But all the dash stuff worked fine.
Now I have ripped out all the CCM stuff, new Painless harness has a wire that you can run to speedo
Old Mar 12, 2009 | 04:21 PM
anesthes's Avatar
anesthes
Now or before?
Yes, but the odometer is contained in the CCM, so your car won't display mileage.
I realize that the PCM will output the 4k PPM signal to drive the actual speedometer, but the odometer is stored in the CCM flash memory.
That is the huge heartbreak. I didn't want a car that would have a ZERO readout on the mileage.
-- Joe
Old Mar 12, 2009 | 05:03 PM
nlk2005's Avatar
nlk2005
The only ones that i saw were for '94's and up. Where did you get yours from? I just really dont feel like doing any tuning myself and if there is a place that custom tunes the eprom chips then speak up
Old Mar 12, 2009 | 06:24 PM
DVNCI's Avatar
DVNCI
-- Joe
Yeah but I could care less about mileage, my Autometer speedo will begin accumulating mileage. As far as I'm concerned it's a new car now.
I'll have this car til' I'm dead so keeping existing mileage value is not an issue. If you are reselling yeah I see where that would be a concern.
To swapping computer ?s
