1985 Vats?
Old Mar 23, 2009 | 09:17 AM
shamdave's Avatar
shamdave
Default 1985 Vats?
Does an 85 have a Vats? Here is why i ask I am haveing an issue we
Eliminated The key and put in a push button start (with an arming switch for the acc/ battery) now the car will turn the Acc back even if the switch is off? Any one have a clue on this one
Could it be the Vats?
Old Mar 23, 2009 | 09:32 AM
bjankuski's Avatar
bjankuski
I do not believe an 85 has VATS.
Old Mar 23, 2009 | 10:36 AM
shamdave's Avatar
shamdave
It has the security system that disables the starter isnt that the VATS
Old Mar 23, 2009 | 10:39 AM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
Yes the 85 has a security system but no vats. The vats system uses a resistor pellet on the key as part of the security system. If I'm wrong someone will chime in.
Old Mar 23, 2009 | 10:46 AM
shamdave's Avatar
shamdave
Ahh now i see It has (had) a normal Key. So any one got any Ideas on the gremlin?
Old Mar 23, 2009 | 10:52 AM
MK 82's Avatar
MK 82
Talk to the "we" that chopped up the electrical system. How could we possibly know what was done?
Old Mar 23, 2009 | 10:57 AM
engle1147's Avatar
engle1147
Vats in '85 was called TDS (theft deterant system). The TDS system got its power from a the horn circuit.....there is also a fues in the horn circuit just before the splice point that feeds the TDS.
To 1985 Vats?
