Noticed a few things about the Vette when I bought it yesterday. Please help.
Re: Noticed a few things about the Vette when I bought it yesterday. Please help. (92TripleBlack)
You should be able to kill most squeeks and rattles. I have almost none through good maintence even though it has 70,000 miles with alot of northeast potholes on it. New tires will also help the ride quality. Since you are looking at tires, you may want to upgrade to 17 inch rims now. They look great and make a big difference in handling.
My 92 tranny has always had a small hesitstion in OD. If you pull it down to 'D', mine goes away, but the whole torque converter idea sounds right to me. As far as your radiator drain, the plug screws in, but last time I had my radaitor out, the back end of the plug, witch is what it scews into, fell down (I had it laying flat) so you might look at that idea... my car is a 92, so the plug might be different, but that is what comes to mind when I read the post. Go firestone in my preference, and good luck with the squeeks!!! :lol:
Re: Noticed a few things about the Vette when I bought it yesterday. Please help. (VetteNoob)
1. When driving at cruising speeds, if I let off the gas and slowly reapply the gas, it will run up 500-700 rpm before the tranny catches. It does not feel like slippage. Could this mean that the tranny is needing some servicing or is it normal? (Most important HELP request)
This could the torque converter locking and unlocking. The trans will usually unlock when you let off the gas and then lock after some steady cruising.
2. Acceleration feels a little sluggish.
Rearend ratio, plugged cat, plugs....
4. Tires. Any recommendations? 16" factory wheels.
Try Kumho, I don't know if they make 16s but good tires at very good prices.
6. The driver seat feels loose in it's bracket. The seat is bolted tight to the chasis, but it rocks a small bit. Anyway to fix this?
This is an annoying fact of life with these seats until someone finds a fix. My 94 has it too. You can reduce it by setting the rake of the seat so there is less leverage on the seat tracks.
Re: Noticed a few things about the Vette when I bought it yesterday. Please help. (R Cook 92)
The drain plug is a 3 piece unit; a stem, a seal and the body. Make sure the seal (looks like a plastic washer) is flush with the end of the stem and not past the lip of the threads. If it is it won't reach the body and tighten. When I first removed mine the seal moved and it took me a while to figure it out since I never saw this type of drain coc$ before. Just push it back flush.
Re: Noticed a few things about the Vette when I bought it yesterday. Please help. (skidmark)
Can anyone send dis-assembly directions for the drain plug? All mine looks like is a single plastic wing nut that doesnt go in or out. No housing assembly like most drain plugs. Id hate to have to spend $150-$200 if I can fix it cheaper.
The radiator doesn't have a drain plug. It uses some kind of drain valve. No way to actually replace the valve. ASC radiator or something like that. So I am just going to replace the radiator.
A friend changed my drain plug when it sprung a leak so I can't tell you how to pull it out.
Re: Noticed a few things about the Vette when I bought it yesterday. Please help. (VQT88Vette)
Copied from my other post:
http://forums.corvetteforum.com/zerothread?id=232293
Does anyone have access to a digi cam and the GM shop manual describing the drain plug removal procedure? This is what the drain plug looks like and I have no clue how to take it off or if it is even possible. Id rather not have to buy a new radiator if I can fix this new one. Everyone has said that drain valve comes off and can be replaced, mine just free spins in both directions with no end in sight.
Or even directions on how to remove this drain valve/plug. Thanks.
[Modified by VetteNoob, 12:45 PM 2/4/2002]
I bought Kumhos at http://www.tirerack.com, they were $92 each and I like them a lot. They were around $400 shipped.
Re: Noticed a few things about the Vette when I bought it yesterday. Please help. (Fastguy)
I was checking out some Yokohomas (AVIDS). Anyone used these? I've had the Yoko's on my Honda before and they were nice, but seeing my Honda is nothing like a Vette, I dont know how they would be. Tirerack gave it a 4 1/2 star rating. That's actually better than the Firestone's rating.
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Re: Noticed a few things about the Vette when I bought it yesterday. Please help. (Glock'94)
Too small for yours. :D 16" I think on the 88.
Re: Noticed a few things about the Vette when I bought it yesterday. Please help. (Blue 92)
#33
I bought a couple of Kumho's 275/40/17's for $130 a piece locally in Jax. I was not impressed with their handling or ride, but my car was not designed for 17" wheels either ( 87 came with 16's, now has Z51 9.5" 16's on and lovin it ).
