what are some good first mods on a LT1?
1 Post
Cruise-In III Veteran
Re: what are some good first mods on a LT1? (Sean6293)
Cut open the air cleaner lid and get a K&N, bypass the TB coolent lines, maybe a set of muffler elims if you want a better sounding exhaust. 160 Tstat and some way to turn the fans on sooner... after that, things get pricey :)
There isn't that much free HP to be found on an LT1. Open up your air lid and do the throttle body coolant bypass, combined they might be good for 2 hp.
Received 1,400 Likes
what kinda results do you think that would yield?
1 Post
The above free mods will do very little, but they are free or close to it and will add up.. it's stuff that doesn't hurt.
Gears will give you the biggest SOTP feeling... but will run you 800+ for gears and install.
Re: what are some good first mods on a LT1? (Springer's 95)
yeah thats a lot, i'm pretty poor. eh, i think i'l just be happy w/ the stock engine.
what are the specs on a stock 6spd 93 lt1 anyway?
300hp at the crank, i think the stock gears are somthin like 3.33. Could be wrong though. You will want a bit more gear though, like 3.73 or 4.10.
Elite Torch Red Member
If you are getting a six speed, just learn to drive the car, I've gotten my 95 6 speed in the 12's with no mods(open lid=0 gain, muff elims=loss of mph)
Re: what are some good first mods on a LT1? (Mr Mojo)
12's stock? awesome!
i consider myself a good driver (last car was a 6speed) i think once i learn it il' be pretty good :)
Come on out to Raceway Park, we got a bunch of us who run there every week(Fri & Sat). Opening day is March 2nd.
Where is nowhere? Gears are the best upgrade. Get 4.09. A k&n is just good sense, not necessary power. i'd put one in for peace of mind first as well as better air flow for later.
New gear is expensive. Since your Vette is a 6-spd, you might already have a 3.45. Check the code to see what gear ratio do you have. If it is GM3, it is 3.45, which is already good. Too big for the gear ratio doesn't mean better, unless you want to have serious upgrade on your engine. Good luck.
YA, I spent a week one night in NOWHERE :crazy:
