86 C4 No Power
Old May 8, 2009 | 12:05 AM
jim70's Avatar
jim70
Default 86 C4 No Power
I'm a long time C3 owner/operator and know absolutely nothing post-C4.
Friend has a 1986 ragtop that is completely electrically dead.Nothing whatsoever..no lights,..nothing.
Is there a main fuse or fuselink anywhere to start with?
Any guidance from you C4 mates appreciated.
PM's best for me...but I'll keep an eye on the thread.
Thx
Jim
Old May 8, 2009 | 12:29 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
This is a very tough question because who knows where to begin?
The C4 is not much different than any other car,as far as basics goes.
It does have TPI and fuel injection,but always go back to the basics.
From your post,I dont even know if your friends car has a good battery or not.
Can you explain more?What has been tested,checked and looked at?
Old May 8, 2009 | 01:24 AM
jim70's Avatar
jim70
Far as I know,a new battery installed....
I'll have to ask further.just wondered if and where the fuseable link may be..or main fuse..or anything post C3 that this car may have??
Thx
Old May 8, 2009 | 01:40 AM
Aggravated4life
Open the passenger side door and on the side of the dash is a fuse box/cover door.Its kind of small.Theres a small plastic panel that has a small **** that turns and opens the fuse box cover.
Start there to check for blown fuses.
Not sure about fusible links.Do find out more,was the car fire,flood damage,etc etc.The engine has a bunch of grounds that are attached at the trans bellhousing at the very top as well.Be sure they are there and not broke off.
Old May 8, 2009 | 03:28 AM
Swift_Striker's Avatar
Swift_Striker
there's a junction block behind the battery for positive cables, a few fusible links there. Make sure the negative battery grounds to the driver side of the engine block. Also check that the negative grounds to the chassis to the right of the battery (also at the same point there should be a braided ground connecting the engine ground to the chassis ground).
There's a connector on one of the small positive wires from the battery, make sure it's not disconnected.
Old May 8, 2009 | 08:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/Power%20Distribution.pdf
To 86 C4 No Power
