can you read this spark plug?
Old Jun 2, 2009 | 11:32 PM
ch@0s's Avatar
ch@0s
Default can you read this spark plug?
what does this look like to you,rich? too much timing?
Old Jun 2, 2009 | 11:36 PM
ApexerER's Avatar
ApexerER
Blurry picture but to me it looks lean, What color is the tip of the electrode....
Old Jun 2, 2009 | 11:44 PM
ch@0s's Avatar
ch@0s
its black according to my tuner my car is running rich but it looks lean to me too
he thinks I have a vacuum leak
Here is a snapshot of datamaster
Old Jun 3, 2009 | 12:29 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
turn you camera's macro on
Old Jun 3, 2009 | 12:35 AM
ch@0s's Avatar
ch@0s
it was taken with my blackberry... it sux huh?
Old Jun 3, 2009 | 12:37 AM
StealthLT4's Avatar
StealthLT4
Move it further away so the camera can focus. Then you can zoom in. Even if its digital zoom after the pic's taken, it'll be in focus.
Old Jun 3, 2009 | 12:40 AM
slickfx3's Avatar
slickfx3
table looks good
Old Jun 3, 2009 | 12:46 AM
ch@0s's Avatar
ch@0s
Originally Posted by slickfx3
table looks good
lol i'll trade it for a running vette
Old Jun 3, 2009 | 02:42 AM
383vett's Avatar
383vett
plug looks like it moving real fast!
Old Jun 3, 2009 | 08:16 AM
ch@0s's Avatar
ch@0s
ok guys, thanks for your help.
I talked to my tuner he is going to send me a new tune and I am replacing my plugs.
Old Jun 3, 2009 | 08:56 AM
mseven's Avatar
mseven
Originally Posted by ch@0s
The snap on the left doesn't tell the whole story, the histogram when clicking on a cell tells the average.....however the dark red shows very rich, including de-cell. The white blocks/cells in your histogram shows cells (rpm vs. load) that are functioning about normal. The base of that plug despite the picture qualty looks completely sooted. I also wouldn't be flooring the car (100kpa areas)until you have the tune sorted out.
Did you read what I posted yesterday when you said the BLM was 108?
Old Jun 3, 2009 | 09:23 AM
ch@0s's Avatar
ch@0s
Originally Posted by mseven
The snap on the left is still in open loop, the histogram w/out clicking on a cell doesn't tell the average.....however the dark red shows very rich. The white blocks/cells in your histogram shows cells (rpm vs. load) that are functioning about normal. The base of that plug despite the picture qualty looks completely sooted. I also wouldn't be flooring the car (100kpa areas)until you have the tune sorted out.
I did, thanks for the advice. You are the man!
Hopefully soon after 9 months and 5 teardowns it will be right
Old Jun 3, 2009 | 09:39 AM
grumpyvette's Avatar
grumpyvette
http://forum.grumpysperformance.com/...php?f=70&t=202
the sub-linked info should help
if the picture was crystal clear a great deal of info about the cylinder temp and burn conditions could be found in the plugs appearance
Old Jun 3, 2009 | 10:02 AM
PLRX's Avatar
PLRX
2017 C4 of Year
valid excuse
Old Jun 3, 2009 | 11:16 AM
mseven's Avatar
mseven
I did, thanks for the advice. You are the man! Hopefully soon after 9 months and 5 teardowns it will be right
your welcome, looking at your snap on the left I also noted that the target AFR 14.63 and not 14.73, additonally the PW at 2.9 is high for only 1350 rpm @60kpa. If you compare that to the histogram you will note that the area is overall rich but not when in trim cell 10 (in the snap). So, that means the ecm bumped into 10 but usually in at that rpm/load you would be in trim cell 4 or 5 (providing no one changed the boundries), which would still be rich. Trim cell 10's boundries are usually above 1600rpm from 50-60 kpa (roughly), also note the ST is low and may have been sinking, which would have then changed the BLM for that cell.
Your min IAC cts. tells me that you still need to bring down the cts. at idle.
Getting a tune right takes time and good datalogs to provide your tuner what is going on and the trend of what is happening w/the fueling, timing etc.. This will take effort on both parties to get the tune consistant and a locked in BLM.
Old Jun 3, 2009 | 11:21 AM
slickfx3's Avatar
slickfx3
the ecm will operate in a broad range and compensate, thats what the o2 sensor, intergrater and the BLM will do, real time
my datalog swings lean and rich all the time, I'm no expert but you may have recored some knock events, if not you many not be too lean.
Old Jun 3, 2009 | 11:28 AM
mseven's Avatar
mseven
the ecm will operate in a broad range and compensate, thats what the o2 sensor, intergrater and the BLM will do real time. I'm no expert but you may have recored some knock events, if not you many not be too lean
, the 02 provides the input, the BLM does not comp. anything....in real time or other wise. The ecm can comp but only to a small degree, and are by nature very slow. Unless it is very close you will have to drive for quite some time for it to comp. There is also a point of no comping in an SD ecm, as the ecm uses look up tables to calculate fueling etc. Try as it might, if the numbers aren't there the ECM has no capability of reasoning...in other words in cannot take numbers provided in the tables and make it equal what it may actually be needed. (for example. 2+2 does not equal 5).
In the snap he provided he has recorded knock events (67 at that point in the log), however it would have retarded the timing and being that his overall blm is 108, does not suggest lean.
To can you read this spark plug?
Old Jun 3, 2009 | 11:37 AM
ch@0s's Avatar
ch@0s
Thanks grumpy! that is usefull info
Old Jun 3, 2009 | 11:44 AM
ch@0s's Avatar
ch@0s
Yes I see that now, my tuner has been great and very patient with me.
Old Jun 3, 2009 | 11:58 AM
slickfx3's Avatar
slickfx3
he has a 32k bin file and possibly a faster computing with his 730 box v. my 165 although the 8192 baud may be the determining facotr
he could constant the INT perfomance closer to the BLM and shorten reaction time.
the engineers design the INT to sense at 20 a second, this means they were and are aware that comps shold be deploy at adequete rates.
I don't know how modified the engine is, this alone may require more comp than the ECM can provide, but I guess that's where the pressure and the sizing of fueling components meet use needs.
