It just never ends. I just got my 350 running great and now I need a 427 and new AFR heads. I should start smoking crack so I don't have money for the Vette.
The plan it to build the best possible combo for my plans. Quality and performance are important, with quality coming first.
Not sure exactly which way I will go. If I put a cage in the clone, I may target 10.50.
AFR is not my only consideration.
Probably a fraction of the price of the All-Pro's.....about $2250 plus any applicable milling and spring/retainer upgrades if needed.
Also, I must assume that was also a raised runner casting which the AFR's are not (conventional height bolt on deal with a 1206 sized entrance).
I have flowed a handfull of the raised runner All Pro heads (in the 245 cc range)....most come in the 340-345 range on my bench @ .800 lift....very close to what a production AFR 235 is going right now. I think your flownumbers look a bit optimistic honestly even for a raised runner head but we are comparing apples and oranges anyway.
We are extremely excited about the release of this product and Im sure much like the other Eliminators, once real world results finally start rolling out, you guys wont be disappointed.
My guess is Jim Barth (TPI421Vette) will be one of the first to try a set so you guys shouldn't have to wait very long for independent feedback.
-Tony
Mine are due to ship 7/17, with inconel exhausts and Ti retainers. Destined for my new 434 with a Vortech YSi, Comp solid roller 242/248 on 115lsa, World single plane machined for MPFI, running a Holley Commander Pro 950 with 75lb/hr injectors.
These heads will want a big big inch motor/big bore and some rpms. I would think a 420" small block is bare minimum for these heads and intent to turn 6500 rpm peak power+. If anyone has the big dart blocks for over 434 inches could use this head nicely.
Not quite the street car build head I would say. AFR 210's will do most anything you could want out of a streetable setup and fit all motors from 383 to 434. There are guys running mid high 10's on fairly mild setups with AFR 195's on 406" + motors. I cant imagine what a big solid roller and 434 will do with 235cc heads
I would love to see the combo's of the guys who are running mid/high 10's on mild setups with AFR's 195's on 406" plus motors.
It certainly can be done. Can you send me some links of those combo's.
I am targeting 800-900rwhp on no more than 14# of boost on pump 91 with alky injection. The 434/AFR 235/YSi/World manifold/1 7/8" longtubes will replace the 383/E-tec 200/T-trim/Holley manifold/1 3/4" longtube combo shown here:
