Blower On & Off
Old Jun 16, 2009 | 09:06 AM
76yellow's Avatar
76yellow
Default Blower On & Off
I've asked this question before with no responce. Thought I'd try once more. My blower motor comes on & off on my 94 corvette. When it comes on I can't turn it off. Anybody with & idea ? Thanks
Old Jun 16, 2009 | 09:19 AM
rodj's Avatar
rodj
Got electronic A/c (C68 ) ?
The blower control module is kaput and can operate randomly supplying power direct from battery to fan.
Unplug the blower motor until you get it fixed to stop battery going flat
Old Jun 16, 2009 | 09:34 AM
lltrevino's Avatar
lltrevino
The blower control module is kaput.
same thing happened on my '86
Old Jun 19, 2009 | 09:27 AM
76yellow's Avatar
76yellow
Where is this module located ?
Old Jun 19, 2009 | 10:50 AM
lt1396corvette's Avatar
lt1396corvette
That happens on my 94 but only if my battery is low.
Old Jun 19, 2009 | 10:57 AM
flynn508's Avatar
flynn508
would that also cause that fan to randomly NOT come on? Every so often in my 86 (with electronic AC) the fan wont come on, as long as I am cruising on the highway it's ok, but heats up quick when I have to stop; then other times, everything is just fine.
Old Jun 19, 2009 | 11:08 AM
rodj's Avatar
rodj
Originally Posted by flynn508
, as long as I am cruising on the highway it's ok, but heats up quick when I have to stop; .
The A/c blower fan or the engine fans?
Old Jun 19, 2009 | 11:09 AM
flynn508's Avatar
flynn508
sorry, engine fan.
rodj's Avatar
rodj
Top of the A/c ducting against firewall ;engine side
Old Jun 19, 2009 | 02:37 PM
SunCr's Avatar
SunCr
Controls send low voltage signals to the module which then amplifies them to control blower speed. The next time it quits, check for voltage on the signal wire - Brown or Tan - at the Module. At "1" it should be 2.5 volts. At "10" - 6 volts. With those inputs, the output - Black/Red or whatever is hot at the Blower should be 4/12. If there is no input, the Controls are faulty or the circuit has an intermittent open. If there's an input but no output, it's the Module. If there's an output but no blower, it's the connector or the blower motor is shot.
To Blower On & Off
