How much HP / TQ would this combo make ?
Old 08-05-2009, 06:43 PM
  #181
Shinobi'sZ
Shinobi'sZ's Avatar
Originally Posted by bjankuski
FYI,
I do not believe you will have any problem with a 2-bolt main block until you start reving more then 6000 RPM. My own experience with my 355 2-bolt main, firebird, 6-speed, superram E-Tec 200 heads, ZZ-409 cam is 80,000 trouble free miles, 6000 RPM shift points, 12.0's at 113 MPH and 20 plus miles per gallon on the highway. (Stock crank, rods, and block)
Well this is good too know....maybe I was using too much Slick 50 back in 1989. I do prefer at least a 4 bolt though for support. But it is good to see that you have got trouble free miles with performance upgrades and have taken your car to the track. Have you ever got an oil analysis done...or does your motor make any noise? Just before my bearings went I was getting a knock...rod rattle and I knew it was bad.
Old 08-05-2009, 06:48 PM
  #182
pologreen1
pologreen1's Avatar
I seen and heard that car of bjankuski, it is damn healthy forsure.
Old 08-05-2009, 06:54 PM
  #183
cumbercr
cumbercr's Avatar
Calderone,
Check eBay. Another SR has popped up if you're still leaning that way.
Old 08-05-2009, 06:57 PM
  #184
Calderone
Calderone's Avatar
It's already on my watch list just for fun,im already in conversation with another item.-
thanks
Old 08-05-2009, 07:33 PM
  #185
cumbercr
cumbercr's Avatar
thanks
When you pull your stock TPI, make sure you hold onto the fuel rail. Most of the SRs on eBay were for F-Body cars. The fuel lines are not routed the same as Vettes. If you currently have a cold start injector, you'll need to cap off the fitting on the rear of the drivers side fuel rail. The SR doesn't use the 9th injector.
Old 08-05-2009, 07:44 PM
  #186
Calderone
Calderone's Avatar
Yes i will use my original rail,yes i know i have to cap it
about the ninth....how can i cap it ? its a simple plug ?
Old 08-05-2009, 07:53 PM
  #187
cumbercr
cumbercr's Avatar
The SR runners and intake manifold will not have a provision for the 9th. So there's nothing to cap or plug. Just the fuel rail. If you get an SR that includes the fuel rail, it will probably have the fuel rail cap you need. Just swap it to yours.
Old 08-05-2009, 08:01 PM
  #188
Calderone
Calderone's Avatar
yes i guess it include the rails !
Old 08-06-2009, 11:43 AM
  #189
slamin1
slamin1's Avatar
See what I find at Carlisle but I think I'm goIng with a modded lt1 intake for mine.
Quick Reply: How much HP / TQ would this combo make ?
