LT1 cam change prices
I'm just wondering if shops in Texas are less expensive then local shops in Kansas. I would consider taking my car to TX if costs are much different.
Competence, experience, and ethics should be the first priority. I doubt pricing will vary by enough to warrant 200-300 dollars in gas, and not being able to check on your car by a local (as local as possible) shop. The further you go away from home, the further away your recourse will be, in the event (In my opinion, a very high percentage.) of a jackleg working on your car.
In summation, I'd look for strong recommendations from smart people that have knowledge or firsthand business with the potential shop or person, not the bottom dollar, which will almost certainly guarantee you will be seeking the services of that "other guy" that you thought was a little too expensive in the first place. I know, because more than half of my work comes from this situation, and has for nearly twenty years.
I'd be happy to answer any of your questions regarding your cam swap, and in my opinion, if you can keep it at home, with a truly qualified shops, that's what I'd do. I do design my own camshafts for each and every client's vehicle, and it's not unusual , from a logistics standpoint, for me to sell out of state, and have a qualified shop install the cam.
That being said, you absolutely, have to consider PROPER tuning to be a part of your cam swap cost, and it amazes me how many people do not. This adds another wrinkle, and here are a couple of optimum scenarios to consider:
-You go to wherever the most qualified cam designer and tuner is, drop it off, and do the one stop shop deal.
-You consult and purchase the cam and components you need from the cam designer(There really is a sizeable difference in increases and driveability between cookie cutter cams, and a properly designed custom cam.), and have a competent shop install it (can they degreee the cam, and do they actually own the tools to do so?), then tune it for you-hopefully they also own the tuning software, and know how to properly tune your car.
-You purchase the cam and all components, have your local guy install and degree the cam, and then trailer or drive it to where the most competent tuner is to properly tune your combination. Hopefully, the same guy is the designer and tuner-this will, again, give you the best results.
If, any of the people or shops you are attempting to qualify for your work, himhaw about anything in regards to the work being performed, (mechanical or tuning), RUN to the guy you can tell know's what he is doing .
HTH
Jim
All it takes is for some dirt to get in there with the cam or for it to get nicked up while installing and you could be spending big $$$ to fix things or do it all over again. I recently read a thread where a shop left a rag sealed up in the intake.
There are few shops who take the time to do things right. Most are concerned with getting paid and getting on to the next customer. I have one Corvette speciality shop in my area that I trust but I still prefer to do my own work whenever possible. http://forums.corvetteforum.com/c4-t...lp-needed.html
