Where'd you put your IAT sensor?
Old Feb 21, 2002 | 04:11 PM
NoWorries's Avatar
NoWorries
Default Where'd you put your IAT sensor?
I installed mine here after making some measurements...
Apparently I measured something wrong as it very slightly contacts the hood.
Been thinking about moving it, but I don't know where...my next thought was right in front of the MAF sensor on the bottom.
Old Feb 21, 2002 | 04:34 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Where'd you put your IAT sensor? (NoWorries)
I put mine on that same side as you but around the corner toward the back. About straight behind the black thumb **** that secures the housing. Sorry I don't have a picture of mine handy. Just go around the corner there and drill it in there. Good Luck.
Old Feb 21, 2002 | 05:57 PM
cesar's Avatar
cesar
i have ths slp claw in my 92 and i am using the air tube attachement on the side because 92 have the electric air pumps i cut about one in the tube and placed the sensor there works great i ran the wire under the air hose tube
Old Feb 21, 2002 | 07:10 PM
KYVette90's Avatar
KYVette90
Default Re: Where'd you put your IAT sensor? (cesar)
Here's mine.
Old Feb 21, 2002 | 07:58 PM
emoshn's Avatar
emoshn
Default Re: Where'd you put your IAT sensor? (KYVette90)
Mine is still in the stock position for a 92. If I move mine to the AIR tube, will I notice any difference?
Old Feb 21, 2002 | 08:12 PM
NoWorries's Avatar
NoWorries
Default Re: Where'd you put your IAT sensor? (emoshn)
Yes, definitely, not Seat of the Pants, but definitely on a time slip. The stock setup gets heat-soaked and lies to the computer, causing timing to be retarded, and full-power isn't achieved.
Old Feb 21, 2002 | 08:17 PM
emoshn's Avatar
emoshn
Okay! Gotta replace the connector anyway, so might as well go ahead and change the location while I'm at it. So you mounted yours in the air tube running from the electric air pump to the solenoid? Any specific spot...or the coolest place you could think of?
Thanks :D
Old Feb 21, 2002 | 08:22 PM
Guest
Guest
Posts: n/a
i got a superram with a ati procharger on mine, any ideas of where to put it on this setup? thanx
Old Feb 21, 2002 | 08:35 PM
NoWorries's Avatar
NoWorries
KYVette's seems to be the ideal setup, out of the way, doesn't get crushed, and is still in the cool part of the intake.
Should work for either car. :cheers:
Old Feb 21, 2002 | 10:10 PM
Hurricane_777's Avatar
Hurricane_777
I've got the AO forced air kit, so mine fit right in the shroud that hooks to the hole in the front bumper.
Old Feb 22, 2002 | 11:23 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Sorry no pix but this is where I relocated mine also.
[Modified by War Machine, 9:24 AM 2/22/2002]
Old Feb 22, 2002 | 11:54 AM
PonyH8R's Avatar
PonyH8R
Default Re: Where'd you put your IAT sensor? (War Machine)
Ok, I will be the dummy. :lol: What is it and where is it on stock?
Old Feb 22, 2002 | 11:58 AM
War Machine
Default Re: Where'd you put your IAT sensor? (kghott)
IAT: Intake Air Temperature sensor
It's stock location is the underside of the plenum. :flag
[Modified by War Machine, 10:00 AM 2/22/2002]
Old Feb 22, 2002 | 01:24 PM
emoshn's Avatar
emoshn
On the LT1 its on the intake snorkle.
Old Feb 23, 2002 | 12:01 PM
KYVette90's Avatar
KYVette90
I would reccomend to anyone doing this to just cut the original connector off of the wires and solder in two longer pieces of new wire and solder the original connector back on. Don't buy the relocation kit, it would be a waste of money when you could do it like I've mentioned. :cheers:
Old Feb 24, 2002 | 07:25 PM
VAHROOM's Avatar
VAHROOM
It is strange that you should mention that KY. I just relocated mine using your procedure yesterday. I hadn't read your post yet and it seemed like the best way to me. I think it is better than the extension cord method. Less things to break. I cut the 2 wires about 4" from the plug. Soldered in 2 lengths of wire that matched color and gauge. I put black silicone over the solder joints. Put heat shrink tubing over the RTV. (Slip the heat shrink on the wires BEFORE you solder. I almost forgot that yesterday) Then used black 1/4" wire loom over the whole thing. Looks nice and works.....I don't know if it really added any performance but ......
V
To Where'd you put your IAT sensor?
