Excessive Cabin Heat
Old Sep 27, 2009 | 01:03 PM
JSki's Avatar
JSki
Default Excessive Cabin Heat
Hey guys, it seems I am getting excessive heat in the cabin from the firewall, is this normal? If not, what can I do to stop the heat?
Old Sep 27, 2009 | 01:41 PM
engle1147's Avatar
engle1147
These things can get a bit warm normally. Check to ensure that your cat or pre cats (depending on year) are not glowing red.
Old Sep 27, 2009 | 02:03 PM
jhammons01's Avatar
jhammons01
^^Yup, Cats.....
I went with a silencer on another car I was building...the amount of heat from the tube was reduced dramatically.
Old School American Steel cars, you could get away with no A/C even in hot Texas summers....but not the newer cars with Cats, you have to have a/c or you could get heat stroke in these cars....
Old Sep 27, 2009 | 03:38 PM
LD85's Avatar
LD85
If you have a manual tranny, heat will come up thru the shift boot with the windows open if the boot is torn, it did on mine!
Old Sep 28, 2009 | 02:13 PM
JSki's Avatar
JSki
Nope, I have an auto and the heat is rediculous after it's been running for awhile. Engine and tranny temps are normal so it would make sense if it's the cats. The question now is to replace them, hollow them out, or go with straight pipes? I do have emissions testing I have to go through with it, but I doubt anyone is going to get under this thing to check for cats with how low it is. What are the suggestions? Also, does the aftermarket make o2 simulators for these things?
Old Sep 28, 2009 | 05:15 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Depending on your emission test requirements you will most likely not pass if you remove the cats. They don't looks to see if you have them .... you just willl not be able to pass the test if you don't have them. There should be a metal heat shield between each cat and the floor pan of the car. Jack it up (safely) and get underneath and check to see if one or more of them have fallen off.
I don't see any indication of what year car yours is so I'll assume it's an LT1. Your cats are on each side of the trans and the heat is probably coming from the trans tunnel rather than the firewall.
Old Sep 28, 2009 | 05:23 PM
JSki's Avatar
JSki
Correct on the LT1 (95), the heat shields are on both the cats (been under it a lot lately dealing with o2 problems and a power steering leak that is yet to be fixed). It does seem like it is coming more from the tunnel as well, but very low on the tunnel. I also think there is a tranny heat shield in there, but I can't recall off the top of my head.
Old Sep 28, 2009 | 06:45 PM
jhammons01's Avatar
jhammons01
The O2 sensors should be in front of the Cats.....But that LT1 has four so I am not sure...maybe I heard that there were 2 in front and 2 behind the Cats.....
I'd not pull the Cat out. I would however go to a "real" muffler shop and ask for a "test" pipe. If this cures your problem then you may want to swap out the Cat for a Magnaflow or a Flowmaster equivalent new cat.
They also can install heat shields for you......again a "real" muffler shop....Midas does not really fit into that description.....
These guys are in Buena Park and they are EXCEPTIONAL.......
Old Sep 28, 2009 | 10:25 PM
JSki's Avatar
JSki
Strangely enough, mine has two in front, and only one down stream (right side)... that is unless the other down stream is half way down the drivers side near the muffler, which I doubt. I'm assuming the original vette setup is 2 into 1 pipes and mines been converted to true dual. I'm not sure though.
Old Sep 28, 2009 | 11:04 PM
pcolt94's Avatar
pcolt94
I think only starting in 96 that they had the 4, O2 sensors. It is basically for the OBD2 setup. The rear 2 only check the exhaust but the fronts are the ones that change the A/F mix.
I believe the 95 has 3, O2 sensors as does the 94.
Just a far out thought. I’m sure you are running the A/C this time of year and it is OK. Even if the system was off if the mix door was in the heat position it will let heat in the car.
Old Sep 28, 2009 | 11:16 PM
JSki's Avatar
JSki
Negatory ghost rider, I don't run the ac much cuz i've been running with the top off and the weather has been nice. Also that theory is blown out of the water because I just noticed the other morning when it was in the low 60's and I was on my way to work that my heater core must be bypassed or a blend door not functioning because my heater doesn't work. I've yet to inspect it thoroughly or even burp the system to be sure, but so far there's no heat from where it's supposed to be coming from.
Also, the cats are a viable reason for the heat since I had a bad o2 sensor causing the car to dump fuel for awhile so it wouldn't surprise me if the cats are gone knowing that the previous owner couldn't fix the problem either.
Old Sep 28, 2009 | 11:47 PM
Mr. Peabody
That would be correct. From being under the car you know that the drivers side cat is right down there in front of your right foot. My 95 is the same way. It's a pia in the summer but nice in the winter. A lot of guys pull up the carpet and install an aluminized heat shield mat under the carpet. And your 95 does have 3 02 units, two in front and one behind.
To Excessive Cabin Heat
