What Size Slicks and Wheels to Buy?
Old 10-01-2009, 08:33 PM
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
Originally Posted by rickreeves1 View Post
I might give these a try. Anyone have them? They fit a 17" rim. The widest I see is 275 though.?
Mickey Thompson's legendary race tire technology comes to the street with the ET Street Radial. Built using the latest in high tech radial construction techniques and years of drag racing experience and compound development, this D.O.T. approved street legal drag radial will get your car down the track in record time and drive you home with sure handling and an excellent ride.
Soft Compound For Superior Traction On The Drag Strip
Radial Construction for Excellent Ride Control on the Street
Low Void, Directional Tread for Maximum Dry Traction
Special Sidewall Construction for Quick Launches.
CAUTION: It is not recommended that radial and non-radial tires be mixed on the same vehicle..
MICKEY THOMPSON COMPOUND SELECTION CHART
Medium--------------------------------------------------------Soft
R2
R2 - Special Compound for ET Street Radial
http://www.mickeythompsontires.com/s...ETStreetRadial
This is the tire you sholuld be using.
You have to grind the fins off until they are almost gone.
It doesn't hurt anything just alot of grinding.
You also have to be careful where the weights are intalled.The weights will hit the brake and pull ,stick weights only.You need to install the weights to the inside.
I would go with the MT DR
REDC4CORVETTE is offline
Old 10-01-2009, 09:10 PM
mackeyred96
CF Senior Member
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
15" dia, 10" wide rim 7.5" backspacing, with a 5/16 wheel spacer. You'll need longer wheel studs and the fins on the larger brakes will need to be grind down.
Rear tires with that wheel combo will fit everthing form a 11.5"x15"x28" drag slick to a 13.5"x15"x28" et street.
With a drag radial i used the 325x17"x26".
mackeyred96 is offline
Old 04-30-2016, 07:19 PM
HOT_ON_UR_HEELS
Junior Member
Originally Posted by pr0zac View Post
yes it will fit
I have 86 corvette and want the same slicks but I won't be surprised if I start breaking stuff
HOT_ON_UR_HEELS is offline
Quick Reply: What Size Slicks and Wheels to Buy?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
