lq9 into a c4??
Old 11-09-2009, 01:52 PM
hot85vette
hot85vette's Avatar
Default lq9 into a c4??
Has anybody swapped a lq9 into a c4? Some people have been telling me to go with that instead of an lt1 it would be cheaper and probly faster as well. any info would help thankyou
Old 11-09-2009, 02:47 PM
coupeguy2001
coupeguy2001's Avatar
2021 C4 of the Year - Modified Finalist
The negatives
The two big things here are smog checks and adapting everything to work with your instrument panel which won't work any more, so you need to make a new instrument panel.
1. You would have to have a vehicle speed sensor and a speedo cable
2. some sort of tach interface box,
3. some way to get outside air under your hood and add an air filter
4. custom headers and exhaust with 4 O2 sensors
5. modified trans and custom driveshaft
6. modified torque arm, (no place for a crossmember)
7. adapt all the accessories....pwr steering, A/C, smog pump, alt. etc.
8. modified bigger radiator,
9. modified fuel lines and return lines,
10. modified cooling fan system, (LQ9 has an engine driven fan)
11. Modify the oil pan for clearance
12. Mount the new ECM
13. Modify the new wiring harness
14. fabricate a resistor bank to simulate sensors you are not going to use
15. add an oil cooler
The positives:
1. you can buy engine mounts
2. you can buy trans adapters
3. you can buy a harness
4. you can buy exhaust
5. you can buy an engine complete for about $3500
6. You can buy a corvette LS-1 pan and modify it
7. You can buy a custom radiator
after about $8,000, you will wish you bought a good used TPI engine and made it work with your stuff.
Old 11-09-2009, 03:15 PM
lt1396corvette
lt1396corvette's Avatar
Originally Posted by coupeguy2001
The negatives
The positives:
I never liked the idea of putting a truck motor in a car.If I was going to do it I would buy the vette LSX motor.I would much rather build up a gen1 motor.
Old 11-09-2009, 03:37 PM
pr0zac
pr0zac's Avatar
there is like 700 threads about this if you would either learn to scroll down or use the search function.
Old 11-09-2009, 08:14 PM
Mojave
Mojave's Avatar
What's wrong with an LQ9? Yeah, it's a 'truck' engine, but it's a truck engine that blows away every L98 and LT1, especially with a few choice modifications (like a cam). I would have no reservations about swapping in an LQ9 (or an LQ4, or L92, or any other LSx based engine).
The negatives
The positives:
That's sort of right. The stock dash will continue to work, except for the MPG read outs. If that requires a new dash, then yeah, but otherwise, it will work fine. You don't need 4 O2 sensors, the rear 2 are quite easy to tune out. You can use your factory fans, don't have to use a mechanical. F-body accessories fit fine. F-body pan doesn't require any modifications to clear (C5 batwing pan is huge and is not recommended). You don't need any custom radiator, the stock one is fine.
Old 11-09-2009, 08:48 PM
lt1396corvette
[QUOTE=Mojave;1572096201]What's wrong with an LQ9? Yeah, it's a 'truck' engine, but it's a truck engine that blows away every L98 and LT1, especially with a few choice modifications (like a cam). I would have no reservations about swapping in an LQ9 (or an LQ4, or L92, or any other LSx based engine).
OK show me a LSX truck motor with no changes that got swaped into a c4 and it blows away a lt1.
Old 11-09-2009, 08:55 PM
COPO
COPO's Avatar
I would put one in mine.
Old 11-09-2009, 09:03 PM
CorvetteMike2024
Corvette Junkie
Support Corvetteforum!
CorvetteMike2024's Avatar
Received 2,021 Likes on 839 Posts
Default Lq9
Pardon my stupidity, but whats a LQ9?
Corvette Mike
Old 11-09-2009, 09:37 PM
Rodzilla71
Rodzilla71's Avatar
LQ9 is a 6.0 High Output Truck engine, found in Escalades and a few other models. Close to 350HP and if you add gen IV L92 heads to it will bring you close to 400HP and an added bonus is they are much cheaper to find then an LS1,,,,$1500-$2500 range. I want to put one in my '84 next year but carb it cause I dont want the wiring nightmare involved with fuel injection.
http://en.wikipedia.org/wiki/GM_Vortec_engine#LQ9
Old 11-09-2009, 10:51 PM
pologreen1
pologreen1's Avatar
great info /\
Old 11-09-2009, 10:58 PM
Mojave
Mojave's Avatar
347 hp and 380 ft/lbs of torque vs 300 and 330 ft/lbs. 50 more hp and 50 more ft/lbs is pretty good, and that is with the long runner truck intake. Throw an LS6 intake on it and I bet you'll pick up a bit more power.
Cam-headers LQ9's are over 400 RWHP with nothing else. I've never, ever, EVER, seen a stock-head (not ported), stock intake N/A LT1 do 400 RWHP.
Old 11-09-2009, 11:13 PM
COPO
COPO's Avatar
there is also the ly6, which is 370hp. I have heard that a cam & tune will produce about 100 more hp using the VVT. Dont kno yet but I plan to find out.
Old 11-09-2009, 11:41 PM
lt1396corvette
So your talking on paper.No real world experience.Thats what I thought.Talk is cheap.And you do alot of it.
Old 11-10-2009, 12:10 AM
Mojave
Mojave's Avatar
First off, it's you're, not your. Apparently talk isn't free, because you screwed it up.
I'm really not sure what you are saying. Are you debating the factory power rating of the LSx engines? Are you saying 50 hp & 50 ft/lbs isn't a big step up? Are you saying LSx's don't make power with a few modifications? Are you saying there aren't any LSx swapped C4's?
If you are more specific, I can explain my logic further, and get some dyno charts to back up my 'cheap talk'. I'm certainly no engine god, but I do know LSx's make lots of power. I've got an LT4 that I built and LS1 (still stock), so I've wrenched on both (sometimes more than I'd like...).
Old 11-10-2009, 12:23 AM
lt1396corvette
Thanks for the spell check.You said an lq9 blows away a lt1.So i want to see an lq9 in a c4 vs an lt1.Not a modified lq9
Old 11-10-2009, 12:26 AM
pr0zac
pr0zac's Avatar
you're out of your mind and very argumentative
Old 11-10-2009, 12:29 AM
lt1396corvette
Wow,you should'nt be talking
To lq9 into a c4??
Old 11-10-2009, 01:36 AM
pr0zac
pr0zac's Avatar
at least i have somewhat of a clue of the subjects i may or may not agree with.
Old 11-10-2009, 01:58 AM
Mojave
Mojave's Avatar
Actually, your spelling was perfect (all your words were properly spelled), but your grammar was incorrect.
As far as I know, no one has done that swap. So in one sense, you are right, I can't prove it. But on the flip side, you can't prove me wrong, and the numbers suggest it would be faster. If you have some numbers that suggest otherwise, please share.
Old 11-10-2009, 06:29 AM
lt1396corvette
The way I look at it GM built this motor to go in a truck,not a car.For it to work in a car you are gonna have to mod it.That's why I said I would go with the the vette motor for a swap.Just sounds like a better and easier swap.I don't think there are people on the F-body forum swaping truck motors in there cars.So I don't see why someone would want to do it with there vette.
Quick Reply: lq9 into a c4??
