L98-no juice to fuel pump fuse
Fuel pump oil pressure switch circuit does it exist
Raypdq This is on a 1990 base model coup.
Jumping oil pressure switch for fuel pump circuit
There or three wires in the plug in a triangle configuration. in a oval plug the pins are top of the oval and bottom of te oval and a pin next to the side of the oval. I will check before aplying power but the top and the bottom should logically be the circuit and the pin on the side should be the sensing pin for the switch. I am kind of goingby the seat of my pants on this armed with only inf on this site and a deep back ground in troubleshoot these kinds of problems. I have no manual or access to a wiring schematic and son't know a place to get them. Any help would be apriciated. Thanks Ray This on a 1990 base coup. I know there where chanes in this area from 89 to 90, for instance the relay on the 90 is on the passenger side dash board, so that is why I am trying to verify this circuit is in the 90.
Thanks for all the help, I got an edjucation on the fuel delivery system on my C 4 however that was not the problem. Ended up being that the rotor screws came loose and the rotor destroid the inside of my dist. cap and coil. Repalced everything and good to go. If I hadn't recently had a fuel pump problem the ignition would have been my knee jerk direction to go. Thanks again for all your help, Raypdq
Rotor screws came out and destried the dist cap and coil. Cleaned up and replaced everything and work great. Thanks again for all the help. Raypdq
