Dana-36 years
Old Nov 15, 2009 | 05:36 PM
C4vettrn's Avatar
C4vettrn
Default Dana-36 years
Are all DANA 36's the same? Will a center section from an 89 work in a 92 rear end ?
Old Nov 16, 2009 | 06:52 PM
93 ragtop's Avatar
93 ragtop
I think they are all, basically, the same from 85-96. The only difference may be, which I ran into, the lower control arm brackets use a smaller bolt on the earlier ones. I drilled mine out to the larger dia. The bolt I am talking about holds the lower control arm bracket, and it passes through the case, so its not threaded. Its really no big deal to drill it out.
