Help!!!!EGR pipe block off?!?!!!
Old Jan 18, 2010 | 09:32 AM
herman8tr's Avatar
herman8tr
Default Help!!!!EGR pipe block off?!?!!!
I have a 1990 L98 and I'm changing out the stock exhaust manifolds with headman long tube headers. In any case, I need to know if I can BLOCK OFF the EGR pipe located on the passenger side rear of the motor from the intake manifold to the old exhaust manifold.
Any and all help is greatly appreciated.
Thanks,
Jeffrey
954-292-3705
Old Jan 18, 2010 | 09:54 AM
WW7's Avatar
WW7
You can either block it off or get the headers with the hookups for your egr..Also you may want to consider what the emission laws are in your state. The emission laws are getting tighter and tighter every year and more are doing visual inspections.You will also have to delete your AIR pump because there will be no hookup for that on the headers without egr..If you do decide to block it off you will need to make or buy block off plates for your manifold , also to stop from setting a code you will have to have the egr eliminated from your chip.If you don't eliminate the egr from your chip you could have problems with excessive combustion tempertures which can cause pinging....WW
Old Jan 18, 2010 | 10:06 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Yes, I made mine from 1/4" aluminum plate.
Old Jan 18, 2010 | 10:27 PM
Calderone's Avatar
Calderone
i've seen someone put a coin there !
but you can buy block off billet plates off ebay
Old Jan 24, 2010 | 09:07 PM
herman8tr's Avatar
herman8tr
Thanks Guys!
To Help!!!!EGR pipe block off?!?!!!
