89 Vette No Injector Pulse
1 Post
Did you do some work on the engine prior to the starting issue. On my 89 I had the same issue. I was working on my intake and some how the distributer wire from the tach got caught under the intake pipe and it shorted out. You could not see the wire from the top, I found it by luck. I repaired it and it started right up.
Good Luck !
Good Luck !
Good Luck !
Good Luck !
No work has been done on car prior to it not starting the vette sat for a couple of weeks then it just would not start
Supporting Vendor
just read his thread.. a few questions, how long was this engine not running? I think you have stuck closed injectors. In this scenario the injector coil will ohm check fine. But the valve seat wont move. I know you said there is no pulse in the noid light but I'm not convinced its not stuck injectors. Those multecs have a mind of their own. Also, they cannot be cleaned successfully. I read this quickly off my i phone so i might have missed something. But, if you haven't tried some starting fluid, I would. see if it fires on ether, if it does you can rule out, ignition.
You said you replaced engine 4000 miles ago,right? I would chase all harneses related to engine managment for pinch points, and recheck all grounding points that would have been removed during engine RR.One of the harneses could have been pinched or rubbed leading to an open or short situation. That computer needs to have sucessful comunication with scanner before any thing else. Just my 2 cents,what do I know I own a c3
Is the pulse signal getting to the injectors? If so, the only thing I could think of that that point is something in the fuel plugged them.
ETA: but what would plug all of them, all at once...presumably the car would run, but run like crap.
There's an oil pressure fuel cutoff circuit, too. If that sensor sees no pressure, it cuts power to the fuel pump. Do you have fuel pressure to the rail? (this thread is rapidly approaching tl;dr status)
Based on you saying the SES light is flashing a "12" Here's what I'd do--- All voltage tests at the ECM connectors
A--check the orange wire in the 32 pin connector for battery voltage ALL the time
B--check the orange wire in the24 pin connector for battery voltage ALL the time
C--check the pink/black wire in the 24 pin connector for 12 volts w/ignition on
D---KEY OFF--Using the ohm scale of your VOM---check the black/white wire for continuity to any KNOWN GOOD ground
Post back with what you find
#33
I"LL try some more checks on monday at the ECM for voltage and ground That TWISTERUP suggested
engle1147 I have done the noid light test with all injector pigtails off still no pulse
Cant work on the vette tomorrow I'll be outta town
#35
#36
I know you said you have VATS bypassed and you've tried a couple reman ECMs---I'm thinkin' out loud here---Is it possible the prom you also had burned which among other things" Eliminates VATS"--has gone **** up ??
#37
#38
That's something a good set of 4' test leads with alligator clips are good for. (I had to string two or three together to test the wiring for a tranny temp sensor once.)
Since NONE of them are firing, You might want to concentrate on testing the ground side of the electrical equation.
#40
Hi!!
Your history is like mine´s...the same:
http://forums.corvetteforum.com/c4-t...e-january.html
I was 12 months with no pulses...a lot of tests, new pieces (ECM´s, PROM...all!!) like you.
And my problem was this:
http://www.youtube.com/watch?v=PcfIHLVcm7A
A connector had a bad adjustment to ECM. In that video, i only touch it a little, and the car stops. That was all
May be is your problem too. Try to move that connectors while you are cranking...may be you will have good luck
Regards from Spain
Regards from Spain
